03-08-2007, 03:37 PM | #1 |
Pebble Pounder Join Date: Jan 2007 Location: Gresham
| Help with yokes
I am building a tlt kit, and I am using the traxxas platic yokes (I plan on upgrading to metal when I get the extra money) I am having a he!! of a time getting the "balls" into the yokes, the "tabs" will not flex enough to get them in. Does any one have any tips on how to make it a little easier. I am doing this for two crawlers and I have spent 45min without any luck on one already. Thanks TQ |
03-08-2007, 03:44 PM | #2 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
put them in boiling water for about 30secs... the plastic becomes plyable. should be abel to do it by hand then.
03-08-2007, 04:32 PM | #3 |
Thanks that worked, still a pain in the A$$ but I got both in less then 10 min.
03-08-2007, 07:09 PM | #4 |
i accept dontations... pm me for paypal info. |
03-08-2007, 07:30 PM | #5 |
Pebble Pounder Join Date: Oct 2006 Location: Westbrook Park,Pa.
hold a small flat screwdriver on the one side to hold in place ,then push on the other side to snap in place.
03-08-2007, 07:47 PM | #6 | |
if you heat them up good, you shouldnt need a screwdriver. | |
03-08-2007, 11:47 PM | #7 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
in alot of traxxas kits they come with a tool specifically made for that task. looks like a rectangle with a notch cut out on one end.
03-09-2007, 07:33 AM | #8 | |
RCC Addict Join Date: Dec 2006 Location: Flatwoods
03-09-2007, 02:31 PM | #9 |
Rock Crawler Join Date: Feb 2006 Location: Easthampton
snap ring plyers work great, use them to spread the tabs and the metal joint slips right in
03-09-2007, 03:47 PM | #10 | |
Pebble Pounder Join Date: Aug 2005 Location: Stockdale, PA
