03-23-2007, 09:35 AM | #1 |
Rock Stacker Join Date: Mar 2007 Location: WV
| Which crawler?
Here is my problem I getting ready to build my first crawler and I trying to decide which will be better for the build. Right now I have a brand new TLT and a brand new Wheely King Any suggestions and help would be great! thanks |
03-23-2007, 10:11 AM | #2 |
Quarry Creeper Join Date: Aug 2004 Location: North Las Vegas
Do you want a full out crawler or just something to play with on the rocks outback? Thinking about competing for anything or just trail running? Some simple questions if answered will help others to point you in the right direction.
03-23-2007, 10:13 AM | #3 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
why choose, do em both!
03-23-2007, 10:56 AM | #4 |
I would like to do both but time and money come in to play.... I am not going to be competing but want a well built crawler
03-23-2007, 10:58 AM | #5 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
Use the TLT axles and the WK tranny...
03-23-2007, 10:58 AM | #6 |
I'd say buy a pimpslap chassis. Super cheap and will handle almost anything. See syco133 for one. Then get a different chassis for the King. That way you can compare.
03-23-2007, 11:25 AM | #7 |
not a big fan of the pimpslap chassis the thing is also I will be selling one of the cars once i make a decision on which one to make a crawler...just because I don't have the time to keep up with my other cars and hobbies |
03-23-2007, 11:47 AM | #8 |
Quarry Creeper Join Date: Jan 2006 Location: colchester
go with the WK. the axles are beefier and wider and mostly better for a basher. but then again you also have to consider that there is not as much aftermarket support for the WK. just look through the different builds for each and see which you like better. IMO the WK is easier to make into a crawler with the least extra money. just add longer links and some better tires and you are pretty much set for awhile atleast
03-23-2007, 12:10 PM | #9 |
yeah but the chassis totally sucks on th WK and your right not much aftermarket support on the WK
03-23-2007, 12:21 PM | #10 |
then go with the tlt now since there is so much out there for it, and then in the future build up the WK. the possibilities for the tlt are almost endless and there is so much knowledge on here about them that pretty much any problem you have with it can be solved with a simple question here. go with an SW2 or SW3 when they come out and just look at some of the builds and get your ideas. once you get going on it its easy to build one. and like i said after wards when time and money permit, build up the WK into something also, until then just use it as a basher
