05-11-2007, 10:06 PM | #1 |
Newbie Join Date: May 2007 Location: louisville
| how to build a tuber.
how do you build a tuber and make it stay together. please dont send me to the how to i dont understand it at all. do i need map gas to do it. what do i use for the hold together part. please help soon. phil |
05-11-2007, 10:21 PM | #2 |
Quarry Creeper Join Date: Aug 2006 Location: NORTH TEXAS
mapp gas torch and brazing rod. make sure you buy way more tubing than you will think you will need. be sure to fishmouth (cope) the joints for better fit and it will not take as much rod to braze it. just get the brazing rod with the flux on it. i know most will tell you to use safty-silv but to learn how just use brazing rod. |
05-11-2007, 11:15 PM | #3 |
what size rod and where do i get that rod at. thanx.
05-11-2007, 11:34 PM | #4 |
i live in a small town so the auto parts store has welding supply stuff too. depends on what size of truck 2.2 or super. 2.2 i use mostly 3/16 od and for super i use 1/4 od. for a 60" (5 foot) of 3/16 is about 4 bucks and 1/4 is about 5 bucks. the brazing rod is about 2 bucks for a 3 foot flux coated brass rod. you will need a good flat file and a good round file for copeing the joints. |
05-11-2007, 11:39 PM | #5 |
thanx for the help. and ant tips or trix would be great
05-11-2007, 11:57 PM | #6 |
get some welders helper magnets, small ones. aligator clips and a good flat place to work on. also you will need a small tubeing cutter, fine tip sharpie, protractor and angle finder (this will be used to make sure all your angles are the same from side to side. be sure you get the tube good and red hot so the brazing rod will flow when it melts. one thing to remember is what ever gets red hot the brass will flow there. clean what ever you intend to braze. most of the time when you heat the metal red hot it will remove anything that might contaminate the joint you are going to braze, i have brazed painted brake line with out clearning off the paint. most of the time if you get brake line from auto zone (auot parts chain store) the are painted greenish, but other stores have galvinized (the good stuff). be sure if you braze the galvanized tube to do it in a well ventalated(?) spot, the galv coating if you inhail enough it can make you sick. but not to worry it burns off fast and then your ok. |
05-12-2007, 12:07 AM | #7 |
ok so try not to get the greenish stuff. my dad has a machine shop and can you weld it. i can weld just not or even know what brazing is. thanx |
05-14-2007, 05:14 AM | #8 |
....Oooops. Didn't notice it was moved to the Newbie Section. Well if this is Flaming...I'll delete it. Just thought it was funny. Just reminded me of this thread when I saw it.
05-20-2007, 01:36 PM | #9 |
Newbie Join Date: Jul 2006 Location: On the Rocks
Is it okay to use JB Weld instead of brazing it? I don't have the space to braze anything right now, but I have a ton of JB Weld.
05-21-2007, 02:28 AM | #10 | |
I wanna be Dave Join Date: Jul 2006 Location: Moscow Mills MO
my throat is sore though.............................. | |
05-21-2007, 02:33 AM | #11 |
