05-23-2007, 10:24 AM | #1 |
Newbie Join Date: May 2007 Location: buffalo
| pick my truck!!!!!
ok i need some help deciding what truck to get. i want to keep it something like a tlt, but i cant afford expensive trucks. i was thinking about a custom frame w/ 4 links and wk axles my 2nd inde was a torsion frame w/ the same axles or tlt's thanks for any ideas!!! |
05-23-2007, 10:41 AM | #2 |
Pebble Pounder Join Date: Apr 2007 Location: Deer Park
get ahold of http://www.reignrc.com/scale.html also a vendor on here and use his chassis..... his stuff is freaking sweeeeet (as sung by peter griffin) |
05-23-2007, 10:44 AM | #3 |
ive loked at that and its one of my tp choices. what do i run for a tranny? this is my first truck im planing to build, im 14 |
05-23-2007, 10:46 AM | #4 |
i forgot, i need to know what to run for links an the ends
05-23-2007, 11:29 AM | #5 |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
Take a good look at the 4x4 wheelie king, it comes rtr. The tranny and shocks will work fine for a crawler, so that saves you some time looking and deciding what to use. Being as its RTR you will already have a useable radio, battery pack, esc, and motor to get you started. None of the electronics are top notch stuff, but you can upgrade as youre budget allows. At $200-$210 its not a bad start.
05-23-2007, 11:30 AM | #6 |
Newbie Join Date: Feb 2005 Location: Tampa Bay Area
Want cheap? get a nylint. |
05-23-2007, 11:37 AM | #7 |
05-23-2007, 12:56 PM | #8 |
hey u got it i need it cheap and reliable!! i think the wk should be good, can i run it with the reign chassi, i wouldmost likley be using the longer one |
05-23-2007, 06:11 PM | #9 |
Rock Crawler Join Date: Mar 2006 Location: Auburn, WA
Buy a 4x4 Wheely King, and then spend a bunch of time reading up on the builds using the stock chassis. You can have a very capable crawler for very little $$ with the WK. Later on down the road, you can save your money and decide where the best place is to invest money toward upgrades you need (maybe a chassis, or an upgraded ESC, or better tires, etc)
05-24-2007, 11:17 AM | #10 |
thanks i think i will use thw wk
