05-31-2007, 08:46 PM | #1 |
Newbie Join Date: May 2007 Location: greenville
| Radio Shack F350
HEY guys i just picked up the radio shack ford f350 4x4 and i was wondering has anyone ditched the stockers and put on some new aftermarket wheels any tips on doing this would be greatly apperciated. DEBO |
06-01-2007, 07:00 AM | #2 |
RCC Addict Join Date: Dec 2005 Location: Beaver Falls
what's it look like?
06-01-2007, 07:45 AM | #3 |
I joined the Band! Join Date: Dec 2006 Location: jacksonville
this thread is worthless without pics |
06-01-2007, 09:50 AM | #4 |
Rock Crawler Join Date: Sep 2004 Location: Santa Rosa
| Here's the link to his other thread in the General Crawlers Forum: http://www.rccrawler.com/forum/showt...329#post722329 |
06-01-2007, 03:23 PM | #5 | |
Thanks for the link. Doesn't that rig use the same chassis as the yellow hummer with mattracks that radio shack sells? Quote:
06-01-2007, 03:35 PM | #6 |
Newbie Join Date: Feb 2006 Location: marquette
06-01-2007, 03:43 PM | #7 |
Pebble Pounder Join Date: Apr 2006 Location: grand rapids
I assume you want to put on some 2.2 wheels/tires for better clearance/traction. If the f350 is stock right now here is a probable chain of events 1. I tell you how to modify for 2.2 wheels 2. You put on 2.2 moabs. 3. The larger diameter makes your truck seem gutless. 4. You modify the motor mount, put on a 8 tooth pinion, and get a better motor. 5. The traction still isn't very good. You lock the diffs. (should be step 1.) 6. This works better, whoops fried the steering servo after 2 minutes. 7. You modify the chassis for a hobby grade servo, receiver, and Moped Esc. 8. This works great...whoops.. three wheel drive. New stub axles from a Hobby grade RC work great, after a three week search to find ones that will fit. 9. Whoops.. three wheel drive. Tranny outdrives are shot. You make your own spools. It can be made into a passable crawler, but in the end it will still be hard to work on, poorly engineered, and generally substandard. If you think I am just being a hater, think again.Rat Shack torsion Now, if you still want to put on different wheels, here is what I did. 1. Remove the steering knuckles/bearing holders. 2. Remove the brass hex. They are pressed on, the shaft has straight knurls. I think I clamped the hex in the vise (not too tight), put a nut on the shaft to protect the threads, and hit it with short hammer raps. 3. After the hexs are off drill a hole through the stub axle for a drive pin. I used Stampede drive pins, wheel hexs, and wheels. This is not an exact science for me and will probably rely heavily on your skills and imagination. Also I am not using Radio Shack stub axles. Drilling a hole through a stock Radio Shack stub axle may result in a broken axle. Good Luck, I always like to see what others have done to this chassis. |
