06-19-2007, 05:14 PM | #1 |
Rock Stacker Join Date: Jan 2007 Location: Queensland
| Back wheels dont turn much when crawling vertical?
Hey guys, Iv noticed with my clod when i climb vertical theres alot more wheelspin and like, none in the rear? Wahats the go and how can i fix it? Thanks. |
06-19-2007, 05:17 PM | #2 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
Too high gearing.
06-19-2007, 05:21 PM | #3 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
It called "Clod Stall", most Clod based rigs suffer from it. Are you running the same pinions front and rear? I've found using a higher toothed pinion in front helps a little, 10t in front and 9t in the rear. Also adding weight to my front wheels helped some too. |
06-19-2007, 05:24 PM | #4 | |
Iv got alot of weight on the front, most of everything is mounted towards the front. Thanks for that guys, i thought it wasn't a common problem ;) | |
06-19-2007, 05:43 PM | #5 |
Quarry Creeper Join Date: Jan 2007 Location: Alberta, Canada
06-19-2007, 08:17 PM | #6 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
06-19-2007, 08:21 PM | #7 |
Instead of making another topic, ill ask the question here. My clod has alloy knuckles up front, now, how the hell can i get the wheel nut off? Im running stock clod wheels and the nut sinks down so i cant get into where it sits, any help? |
06-20-2007, 12:08 AM | #8 |
| Hmm I always think of high gear as high gear reduction ratio...definitions! ...although when I do say gear up I mean to increase the speed lol. Definitions! I guess if you just think about it in terms of fractions then yeah my way is inconsistent and backwaards lol.
