06-23-2007, 11:11 AM | #1 |
Quarry Creeper Join Date: Jan 2007 Location: L.I.
| dual mamba max
I'm currently building me a clod based tube chassis crawler. I plan on using 2 brushless motors, obvioulsy I'll need to use 2 esc. problem I'm running into is I can't find any right ups or diagrams explaining how to wire up this type of setup. would I also need a 4 channel radio for this type of setup? any help would be appreciated. |
06-23-2007, 11:30 AM | #2 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
No, you can run two ESC's on one channel. If you want to run them from one battery then you need to make a Y-splitter, though.
06-25-2007, 10:07 AM | #3 |
RCC Addict Join Date: Jul 2006 Location: barstow
just curious as to setting up the 2 mamba maxes on 1 channel. would you plug in 1 at a time to set your throttle and reverse settings then hook them both up via a y-harness
