06-23-2007, 10:42 PM | #1 |
Newbie Join Date: Jun 2007 Location: La Canada Ca
| 4 wheel stearing
whats the advantage of fourwheel sterring because i was thinking of getting the axial ax10 as my first crawler and 4th rc but noticed that it only had one servo and a few of the guys had 2 servos one for front and one for back thx in advance |
06-23-2007, 11:19 PM | #2 |
RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
well when i had my super i liked and hated the 4ws on it. good makes sharper turns you can crap walk mannover easie dis hard to control needaxtra patiance mor batt power needed to run it need[well i had to] run an rx pack and on and on but on a 2.2 i woulnt suggest using it but on a super or longer wb rig have it it wil also be easyer to do donuts |
06-25-2007, 05:54 AM | #3 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
| Full-time AWS (2-channel w/ Y-harness) is more of a liability than an asset. The rear will go places you don't want it to as you try to steer the front through obstacles. Independant 4WS (seperate 3rd channel for rear steering) is what you want to do (if you don't compete) the rear steering can be left alone and only used when needed, so it has no adverse effect on where the rig is going. Plus you can crabwalk, which is very helpful at times. |
06-25-2007, 05:57 AM | #4 |
| If you search - be sure to search for "steering" - not "stearing" or "sterring" - You'll get better results... |
