08-03-2007, 10:26 PM | #1 |
Rock Crawler Join Date: Apr 2007 Location: APPLE VALLEY,CALIFORNIA
| mamba max problem
ok i have a problem....just finished my 1st crawler but when i hook up the mamba max esc and try to do the calibration all 3 lights just blink and the tones just keep beeping ...i'm following the directions in the book exactly as stated...but cant get it to do anything....any suggestions please...thanks for the help
08-03-2007, 10:28 PM | #2 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
did you do the quick set up first?its on the page before the set up
08-03-2007, 10:31 PM | #3 |
yeah ..thats what im trying to do ..the quick set up
08-03-2007, 10:34 PM | #4 |
Quarry Creeper Join Date: Nov 2004 Location: In the saddle...
08-03-2007, 10:35 PM | #5 |
while holding full throttle,turn on the esc and nothing happens?
08-03-2007, 10:37 PM | #6 |
08-03-2007, 10:41 PM | #7 |
that link is for the mamba 25 ...is that the same ???...also im not using brushless ...this is running 2 55t on a clod if that matters
08-03-2007, 10:44 PM | #8 |
08-03-2007, 10:45 PM | #9 |
08-03-2007, 10:47 PM | #10 |
well they are parellel... esc to rear then wired to the front ..the rear is reversed polarity so the esc would have to be reversed to ...right ?? ok i have that manual here ...which is what that link is...thanks tho Last edited by TIMZKRAWLER; 08-03-2007 at 11:09 PM. |
08-03-2007, 10:47 PM | #11 |
08-03-2007, 10:54 PM | #12 |
i mean the rear motor is wired in reverse so it spins the correct direction...so basically the esc pos. is going to motor neg...and esc neg. is going to motor pos. then it switches at the front motor....am i making any sense...LOL
08-03-2007, 11:47 PM | #13 |
DOOH!!! Join Date: Feb 2007 Location: AZ
That's correct.... Not knowing your full set up (radio & receiver) i'm just going to throw this out there.. Do you have power to your steering servo? is it working properly? You might have batt. power to the ESC but no radio signal.. Does your radio have servo reversing? If so, try reversing the throttle setting.. ESC might not be reading full forward if it's reversed.. |
08-03-2007, 11:56 PM | #14 |
well i first tried it with the tq3 wouldnt work ...then i tried my spektrum still nothing...steering works fine..
08-03-2007, 11:58 PM | #15 |
doesn't even get that far ...all three lites just blink and it keeps beeping as soon as i connect the battery then turn on the switch
08-04-2007, 12:04 AM | #16 |
08-04-2007, 12:11 AM | #17 |
well i tried both ways ...niether will work...now all i have is batt to esc ..esc to recv.....i dont even have servos plugged in ...
08-04-2007, 12:12 AM | #18 |
I see you just edited that to your post.. haha I think it can be only a few things (please don't get offended if they sound supid, but i gotta ask) 1. is the battery wired correctly? POS & NEG. 2. when you plug the ESC into the receiver is the polarity correct? (brown is NEG & should be on the same side of the receiver as the servos NEG wires) |
08-04-2007, 12:15 AM | #19 |
not offended at all ...i appreciate all the suggestions...yes batts are correct and esc is correct
08-04-2007, 12:28 AM | #20 |
Ok cool.. But the last thing i can think of is making sure the ECS is plugged into the throttle port on the receiver and not the battery port.. If your willing to, try this: carefully remove the red wire from the ESC's receiver plug (so it doesn't try and feed power both ways) and use a seperate batt. to power the receiver.. That should have the servos working and feed power to the ECS for signal.. |
