08-13-2007, 09:36 AM | #1 |
Rock Stacker Join Date: Apr 2007 Location: Longmont
| Waterproofing!!!
So I've seen other threads about waterproofing, but didn't find all the anwsers I'm lookin for....I've seen using balloons works, but how does that effect the elecs. heating up and such? I thought about using saran wrap, because it's lighter and maybe allow the heat to excape a little better?!? Also, I've heard waterproof the servos as well, but have seen basic servos unprotected and do fine in water?!? Last....lights, could I just gob some threadlock or rubber cement over the bulbs, along with any exposed wire? Anything you've done thats worked for ya is what I'm lookin for, shoe goo, hot glue, ballons, elec. tape, silicone grease... Thanks |
08-13-2007, 09:45 AM | #2 |
Rock Crawler Join Date: Oct 2006 Location: Tacoma
| Search!!!<all I gotta say |
08-13-2007, 10:13 AM | #3 |
thats what I'm sayin, I did a search, but didn't quite get all the info I was lookin for. I found nuthin about saran wrap...heard a little about shoo goo, saw a lot using balloons, but no solutions for the heat issues.
08-13-2007, 11:03 AM | #4 |
if you have an esc wrapped in a balloon and submerged underwater then it should stay cool anyway. Plus, you could get a moped v16 and youll have no heat problems. Thats what I run in mine and it takes almost a whole pack to heat it up and I run the F*** out of it.
08-13-2007, 11:11 AM | #5 |
Rock Crawler Join Date: May 2006 Location: san diego
Heat on the esc in our low speed crawlers is not usually an issue. I found the balloon and vaseline around the wires and opening works good. I double ballooned the last time because the balloon had got tears in it from use. |
08-13-2007, 03:33 PM | #6 |
I wanna be Dave Join Date: Jun 2007 Location: Canada, eh.
I wouldn't go with the saran wrap. Too thin and too hard to make sure it's fully sealed around electronics. Note that some esc's and servos are waterproof which is why you may have seen people running them with no protection. As for lights (I'm assuming you mean led's, right?), probably shoe-gooing up the connections is your best bet. Are you running them off of a 9V or your battery pack? If a 9V, you'd probably want to balloon/seal that as well. Chris |
08-13-2007, 07:28 PM | #7 |
Yeah, LEDs...off the 9v. I'll wrap em in balloons then with the shoe goo. The vaseline sounds like it'd get gunked up. Also, what about the battery...I have a wired up 3x3 set-up and the solder tabs are exposed! Wrap it too?
08-13-2007, 10:05 PM | #8 |
Quarry Creeper Join Date: Jun 2007 Location: Calgary, Alberta
liquid electrical tape. Just make sure everythings clean clean clean before you put it on
