Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Would you consider this ESC Water Resistant?
Old 08-21-2007, 05:13 PM   #1
Default Would you consider this ESC Water Resistant?
I have packed the interior of my Mamba Max ESC with Dielectric Grease and then coated the exterior, around the base of the cooling fin, with Liquid Electrical Tape, and placed a small strip of Electrical Tape over the USB Port.
I am not trying to make it 100% Waterproof, just safe on the ocasional puddle or splash of water.
Just looking for your input.
Thanks.
wshipley is offline   Reply With Quote
Old 08-21-2007, 09:31 PM   #2
Wouldn't it like overheat?! Beibng that the colling ifns are covered in grease. I'm not sure but I dont think the fins need to be coated as they are for cooling. Cover yourself in that grease, run around, and if your waterproof, i.e. not wet, and dont die from heat exhasution. Good to go. Haha
LtKar is offline   Reply With Quote
Old 08-21-2007, 09:41 PM   #3
MWRCA'er
Mnster's Avatar
Considering the mamba max is half water proof already yeah. Silicone coated chips I belive. I have bombed a few puddles in my rally car with no issues.
Mnster is offline   Reply With Quote
Old 08-21-2007, 11:12 PM   #4
The cooling fins have not been coated in any grease, I guess it is a bad picture, they are clean and dry, the liquid electrical tape is just coating the area where the fin meets the ESC box.
Old 08-21-2007, 11:19 PM   #5
In between.
SACCO's Avatar
I have had my mamba maxx in 4 inches of water several times with only a strip of tape over the USB plug. No problems.
SACCO is offline   Reply With Quote
Old 08-21-2007, 11:34 PM   #6
Keep it real
Tanis's Avatar
Originally Posted by Mnster View Post
Considering the mamba max is half water proof already yeah. Silicone coated chips I believe.
Yep
Tanis is offline   Reply With Quote
Old 08-22-2007, 12:09 AM   #7
It's definitely water resistant, I asked the guys in person at the RCX show. (Then I grabbed a hand full of stickers)
bluonyx is offline   Reply With Quote
Old 08-22-2007, 12:27 AM   #8
Haha okay I thought you said it had grease on the fins my bad.
