Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Integy 55turn motor, ESC?
Old 08-26-2007, 12:40 AM   #1
Smile Integy 55turn motor, ESC?
I have a Tamiya chassis with an installed Integy 55turn motor.
It is 4 wheel drive with locked difs.
I've seen people use the Novak XRS ESC, $50
Is this a reliable ESC for this motor?
As always thanks for your input.
Hoosier Daddy is offline   Reply With Quote
Old 08-26-2007, 12:54 AM   #2
Its My Wifes Money!!!
John Deere's Avatar
What kind of tamiya chassis are you running. There are alot out there. Is it a TLT? A txt or what. We have to have more info than what you have given us in order for us to help you. If its a TLT then yes it will be fine with that as far as I know. I never had any trouble with the lathes I ran on a TLT.
John Deere is offline   Reply With Quote
Old 08-26-2007, 07:45 AM   #3
As far as a 55t motor goes almost any ESC will run it. The thing about the XRS is the brake, but that may be able to be turned off.
clemet is offline   Reply With Quote
Old 08-26-2007, 08:26 AM   #4
The Moped V16r ($30) is a perfect choice for those on a budget needing to run 1 or 2 55T motors.
CPE MT is offline   Reply With Quote
Old 08-26-2007, 09:24 AM   #5
I'm Dracula, Bitch.
JeremyH's Avatar
The Novak XRS is a great ESC to use with that motor. I like it better than the Moped.
JeremyH is offline   Reply With Quote
Old 08-26-2007, 12:39 PM   #6
j0e
pretty much any esc will work with a high turn motor.
the deciding factor is what features you want.
waterproof, reverse, brakes, stuff like that.
j0e is offline   Reply With Quote
