08-30-2007, 08:31 PM | #1 |
Rock Stacker Join Date: Aug 2007 Location: Northern Yea Area
| BB's
I keep in hearing that BB's in the tire is the way too go. Any one hear diffrent?
08-30-2007, 09:57 PM | #2 |
RCC Addict Join Date: Jun 2007 Location: San Antonio, Tx
well it puts weight at one of the lowest points on the crawler so yes it is the way to go, you can also add stick on weights, youll have to play with it to see what weight matches your rig and terrain and your driving style to get the best outcome, howd i do for a newbie who still dosent have a crawler yet :P
08-30-2007, 11:54 PM | #3 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Memory foam seems to be the new trend.
08-31-2007, 06:22 AM | #4 |
Pebble Pounder Join Date: Jul 2007 Location: A-pop-kuh, FL outside Orlando
I weighted the axle and a little in the wheel. I used cut foams in the tires, so no room for BB's
09-03-2007, 08:54 AM | #5 |
Pebble Pounder Join Date: Jul 2007 Location: jonesboro
wow, memory foam?...guess im cutting up my wife's pillow!!
09-03-2007, 06:59 PM | #6 |
09-03-2007, 08:43 PM | #7 |
Rock Crawler Join Date: Apr 2007 Location: portland
| thats what i did. but i still want to try the kreepy foams. they probly have a better response. the temper-pedic foam is a little slow on the rebound and for a short while can feel a little bumpy after hitting some jagged rocks.
09-07-2007, 11:07 PM | #8 |
Newbie Join Date: Aug 2007 Location: Westville
when using the airsoft bbs how do you go about filling up the tires? i used some but i obviously didnt use enough bc when i turn my tires just go flat and i cant turn... do you have to fill it to where the tire is at least 1/2 to 3/4 full when standing up?!
09-07-2007, 11:19 PM | #9 |
Quarry Creeper Join Date: Dec 2006 Location: dot com
I abandoned bbs for that reason. No support. I think a foam/bb combo might be ok, but I didnt test that. One thing I can say is dont buy the heavier/denser airsoft bbs. By the time I got enough in the tire to hold it up it was way too heavy.
09-08-2007, 08:06 PM | #10 |
Quarry Creeper Join Date: Aug 2007 Location: tx
I put enough bb's in my tires that the fronts are 12oz and the rears are 9oz and that is tire rim and all. If you can get a good seal with your tires then you should be ok.
