10-16-2007, 07:32 PM | #1 |
Newbie Join Date: Sep 2007 Location: Arnold
| Traction
Everybody knows that to get traction you need a good tire, there are enough tire combinations out there to fit most peoples needs. But if it doesnt seem to be working add weight. I have found that the little 1/4 oz weight strips fit around the rim. There are limited places to put them, here are 2 places i have found. 1 put them inside the rim before putting in the foam (make sure not to cover the air hole). 2 put them on the rim around your hex 12mm 17mm ect. there is enough clearance around the end of the axle to put about 8 of them, If thats not enough weight you can put thick washers on first before the sticky weights, Washers with a 3/4 in hole work really well, most rims can fit 2 washers. Thanks for reading |
10-16-2007, 08:44 PM | #2 |
RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
| FYI, This isn't anything new... I personally have done both those options, and have been doing it for a while now. And there are MANY others that have been doing that too, along with many other ideas and places for 1/4oz weights as well as other forms of weight. Read a bit in the wheels and tires threads or build threads in virtually every category and you'll find it's been done. I'm not saying it not a good idea, just that it's almost considered common knowledge. |
10-17-2007, 10:18 AM | #3 |
Pebble Pounder Join Date: Oct 2007 Location: Allentown
I also heard about the bb's inside the tires in place of the foam. You fill them about a 1/4 of the way and as the tire turns they stay at the bottom giving good weight and traction.
10-17-2007, 02:08 PM | #4 |
Rock Stacker Join Date: Sep 2006 Location: Coeurdalene
