10-30-2007, 04:58 PM | #1 |
Pebble Pounder Join Date: Feb 2007 Location: Confederate States of America
| MAPP torch??
Will a MAPP self ignite torch burn hot enough to braze steel brake line tubing with pre-fluxed brass brazing rods? DC I've been told it won't, I have a regular blue bottle propane torch and it won't get hot enough. |
10-30-2007, 05:23 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
It's all about the MAPPS....yes, it will.
10-30-2007, 05:28 PM | #3 |
Quarry Creeper Join Date: Jul 2007 Location: Kansas city
It will work, but this will work better http://contractorservices.homedepot....7-effc0676d67d |
10-30-2007, 09:36 PM | #4 | |
10-30-2007, 09:40 PM | #5 |
It works better with oxygen. Home Depot sells a kit that uses oxygen and mapp gas for $50
10-30-2007, 09:49 PM | #6 | |
At over 5 bucks per oxygen cylinder, its getting pretty pricey might quick!!!! Thats why I was wondering if the MAPP torches did the job. That way I would only have to buy one canister to work with. DC | |
10-30-2007, 11:54 PM | #7 |
Just mapp gas will work, but the oxygen helps. Think of solder with a 60w iron verses a 100w iron. Not a big deal, but the money you pump into oxygen alone will add up. I have been asking a ton of these questions lately. I obviously want to build a tuber, but I don't want to keep buying oxygen either. Welders cost to much so I will probly just use the mapp torch I use to sweat copper. I don't think propane would come close enough heat wise to braise steel, but it might do aluminum. Let me know how it works out for you.
10-31-2007, 12:08 AM | #8 |
Quarry Creeper Join Date: Apr 2007 Location: YAKIMA
here is a little sweet torch if i was doing tubers this is what i would go with it does mapp/oxy and acet/oxy either one http://www.littletorch.com/tips.html http://www.littletorch.com/help.html |
10-31-2007, 08:18 AM | #9 | |
DC | |
10-31-2007, 08:43 AM | #10 |
RCC Addict Join Date: Sep 2005 Location: Behind the torch!
The benzomatic self ignite torch works fine. It'll be easier if you use silver solder instead of brass rods. It melts at a lower temp and flows better, giving you cleaner looking joints. with Brass Brazing Rods with Silver Solder http://i105.photobucket.com/albums/m...es/ebay506.jpg Both made w/a Mapp torch. |
10-31-2007, 08:55 AM | #11 | |
I should have used silver solder too. You used safety silv 56 ?? Thanks DC | |
