11-16-2007, 02:29 PM | #1 |
Rock Stacker Join Date: Aug 2005 Location: vancouver,BC
| motor wont trun over ?
ok i got everything setup, hooked up the battery, servo,sodered the wires to the motor and no go. did i hook something up wrong ??? servo is working fine but motor aint turning over.. !!! some help plz... futba receiver tazer speed control integy 55t i just want to it run !! |
11-16-2007, 02:52 PM | #2 |
Quarry Creeper Join Date: Apr 2006 Location: Pittsburgh
Make sure your gear mesh isn't to tight.
11-16-2007, 03:12 PM | #3 |
11-16-2007, 03:12 PM | #4 |
Rock Crawler Join Date: Sep 2007 Location: Colorado Springs
Make sure you did not solder the wires to the same side! I have done that in the past. Another way is to connect the motor straight to a battery and see if it runs. Then start testing each thing from there.
11-16-2007, 03:19 PM | #5 |
Quarry Creeper Join Date: Jun 2007 Location: Sacramento
yeah, you propably hooked the motor leads up to the same side (i.e. both pos or both neg) there should be a little + or - on teh side of the can. Sometimes it's just a red dot for pos. |
11-16-2007, 03:58 PM | #6 |
Rock Crawler Join Date: Aug 2005 Location: Alabama
The motor could even be fryed man.
11-16-2007, 03:59 PM | #7 |
Or something could be stuck in the motor.
11-16-2007, 09:34 PM | #8 |
Rock Stacker Join Date: Aug 2007 Location: Northern Yea Area
also, make sure your servo wires arnt backwards.
11-16-2007, 10:00 PM | #9 |
Pebble Pounder Join Date: Oct 2007 Location: Fullerton
it might be the speed controll i have a 15t tazer and i ran it for a while in my stadiam truck and it worked fine till i put a 55t integy on it and it got all retarded so i just changed it to a mamba max i had layin around the shop so i threw it in and that was the problem i even tried crawling with my 27t bonzi and it worked ok i think that esc just dosent like the lathe motor |
