Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Just got my ax10 put together, is reverse in forward normal?
Old 11-24-2007, 11:44 PM   #1
Default Just got my ax10 put together, is reverse in forward normal?
I picked up my ax10 today. I got everything put together. Using my controller from my e-maxx. Rec. from my old duratraxx evader. Matrix 55turn, and a Novak Rooster 12T Reversible ESC. Wow, it went up the first step to my stairs, right out of the box! Damn, great purchase. Only thing is that it goes reverse when you pull the throttle and forward when you push. This is my first time to build from the ground up. Is it something as simple as having put the steering on the wrong end? Sure would appreciate some input and thanks for the time.
SLOB is offline   Reply With Quote
Old 11-24-2007, 11:52 PM   #2
31st place in 2006 Nats!!
toyofast's Avatar
Throttle reverse switch, flip it and setup the ESC again if needed. At the bottom of the radio.
toyofast is offline   Reply With Quote
Old 11-25-2007, 12:01 AM   #3
Are you talking about the CH #1, CH #2, CH #3 switches at the bottom?
#3 is to the right, #2 is to the right, and #1 is to the left. I hope this helps to explain what I have a little better. Also, the controller is the TQ3 (Top Qualifier). Thanks again, S.
Old 11-25-2007, 12:06 AM   #4
Rockcrawler's Avatar
Channel #1 is steering and #2 is throttle. Turn the radio on and leave the truck off. Just push the switch to the opposite side on #2. Be ready when you turn the truck on though. Its probably going to take off. If it does, setup the speedo again.
Rockcrawler is offline   Reply With Quote
Old 11-25-2007, 12:16 AM   #5
THANKS ROCKCRAWLER! That did it! Gonna put on my hippie killer jacket tomorrow and give this thing some outside time. Thanks again for all of the info. SLOB
Old 11-25-2007, 12:34 AM   #6
No Problem.
