12-11-2007, 09:27 AM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: Carlisle
| help with a castles bec.
Im still new to this whole thing what is and does a bec do? also for the bec what power plugs should be installed and what output voltage do i need? and soon ill be using two servos if that makes a difference. the servos will be a jr9000 for steering and a tower pro mg 945 for the r2d dig. and the batteries are the 8 cell elites split pack. thanks for the help
12-11-2007, 09:39 AM | #2 |
The BEC gives power to your radio and servos. ESC's have a BEC built in, but they are very weak generally. 6 volt output is a very safe place to start, and for your power plug you just need whatever plug you already use. If you don't use any plugs yet I recommend deans.
12-11-2007, 09:23 PM | #3 |
Quarry Creeper Join Date: Nov 2007 Location: southender
Deans 2 pin. the only way to fly |
