12-12-2007, 07:24 PM | #1 |
Pebble Pounder Join Date: Nov 2007 Location: canada
| help plz
ok here i go i need links and dont wont to make them cuz i am not good that that sh&%. and plz tell someing that is going to help. i know i can get traxxas rod end and 6-32 Threaded rod but i am new to this and have no self confidence to do it. so i am looking for a set up that will work that i can buy. i have tlt axles, a pede tranz, TCS Gopher 2.2 Crawler Frame,Traxxas Jato Half Shaft Set,and my uper links are the ones that are at the crawler store that are not bent. thanks so much"thumb sup" |
12-12-2007, 07:37 PM | #2 |
Pebble Pounder Join Date: Nov 2005 Location: Viva Your Mom!!
if you want to stay in the sport for long your gonna have to man up and make some shit, you cant buy skill but skill can get you money if your good
12-12-2007, 07:44 PM | #3 |
its not that its just i spent so much and i dont want to fu$% it up :-(:-(
12-12-2007, 07:51 PM | #4 |
"man up"... the most over-used expression of 2007... anyway, you can't worry about messing things up. You just gotta do it. You learn by making mistakes. David @ Xtreme RC Hobbies (www.xtreme-rc-hobbies.net) makes custom links. |
12-12-2007, 07:59 PM | #5 |
no no i going to make them. i am getting my order soon. and wen i do if i put pics up do you think i will get help on how to |
12-12-2007, 08:51 PM | #6 |
Pebble Pounder Join Date: Nov 2007 Location: Louisville
i was just talking about this with a friend tonight. I buy brake line and cut to length, then put the 6/32 tap'r in a cordless drill. Set her to low, dip the tap in some oil and thread away. when you get deep enough reverse the drill and back out. If you start getting resistance on the tap reverse it ,clean the debris and head back in. Really simple. Oh put the brake line in vise. forgot about that!
12-12-2007, 10:30 PM | #7 |
Rock Crawler Join Date: Apr 2007 Location: portland
LOL. Go to home depot, or whatever your local hardware store is. get some threaded rod. get some aluminum tubing that is big enough to fit the threaded rod through. Buy some rod ends. thread one rod end onto the threaded rod (hold it up to your chassis and axle to mock up how long you want the link to be) cut the threaded rod. thread another rod end on the other side and measure the length of exposed threaded rod (this is the length you need to cut the aluminum tube) cut aluminum tube. Unscrew one rod end, slide aluminum tubing on and re screw the rod end on. You have a link. Be sure to make two of equal length. Cheep and easy. |
