| | #1 |
| Choppin' it up. ![]() Join Date: Oct 2007 Location: SW Arkansas
| Got a slash last week, super early b-day present from the lil-lady. Moved the front shocks to outer holes on a-arms. Front shock oil 55wt, rear shock oil 40wt and additional rear shock limiters on the shafts (1/8" or so) plus the blue factory limiters. Moved rear body mounts up. -2 or -3 degree camber up front little less out back. Toe out up front, toe in out rear. Added 4 oz of rear weight under the esc, helps to plant the rear. Flipped ESC 180 deg, desoldered motor leads and soldered esc directly to motor 4600mah, 7 cell max amps nimh battery, ill get a 2cell lipo soon and switch over to my Futaba 3pm. Have the new proline beadlocks, waiting on the prolines switch tires to come in. I'll get a new UpGrade R/C skin once they release the Reaper skin for the HardCorr proline body. I am going to have to put top soil on the track, sometime. Where I live has lots of gravel in the soil. Super loose track right now with big rocks scattered. Took about 2 hours to make with a small tracked excavator. Triangle shaped with a couple of switchbacks in the middle for the short course and a larger triangle around that on the other side. About 20-25 sec lap on inside and 30-35 lap on outside. Still need to make some more sweet jumps. http://www.youtube.com/watch?v=fDgf8jBF1m4 http://www.youtube.com/watch?v=ld743MvmKKY |
| Sponsored Links | |
| | #2 |
| Quarry Creeper ![]() Join Date: Jul 2008 Location: Minot
| Pretty cool. |
| | #3 |
| SAVE BODILESS SPORTSMAN!! ![]() Join Date: Mar 2008 Location: Arkansas
| DAMN YOU ARKANSAS ROCKS!!!!! Seriously, whats with all the rocks in AR? My boss and I started to build a track out behind his shop a few months ago. I spent nearly as much time picking up and chucking tennis ball-sized rocks as I did moving dirt with the Kubota...what a PITA. |
| | #4 |
| Quarry Creeper Join Date: Nov 2007 Location: Lakewood-Crawlerado
| hmm, I was kind of expecting some insane 20 ft high jump or something like that |
| | #5 |
| Rock Stacker Join Date: Nov 2008 Location: Loveland, CO
| Not bad. Pretty rough track lol. I would for sure be looking for some dressins, maybe bigger jumps? |
| Thread Tools | |
| Display Modes | |
