Go Back   RCCrawler.com Bulletin Board > Miscellaneous > Non Crawler RC's
Thread: Pro-Line Epic Bead-Loc ?
Old 12-14-2008, 12:59 PM   #1
Default Pro-Line Epic Bead-Loc ?
Has anyone put regular 2.2 tires on Pro-Line Epic Bead-Loc? Thanks
wayfastwhitey440 is offline   Reply With Quote
Old 12-14-2008, 01:01 PM   #2
666
666's Avatar
Yep I have tried quite a few with good success!
666 is online now   Reply With Quote
Old 12-14-2008, 01:26 PM   #3
do you think they will work with sand paw's and do you have any pics
Old 12-14-2008, 01:30 PM   #4
666
666's Avatar
I don't have Sand Paws, but I mounted Claws, Mashers and Moabs and they did not pull out.
I did not take pics.
Old 12-14-2008, 01:37 PM   #5
do the tires stick out side the body
Old 12-14-2008, 03:21 PM   #6
what size is the hex on those wheels,
twistedsmily is offline   Reply With Quote
Old 12-14-2008, 03:35 PM   #7
666
666's Avatar
I did not mount on my Slash, I assume that is what you are talking about. But since they are taller tires, yes they will rub as the stockers do also.
They are 12mm.
Old 12-14-2008, 06:11 PM   #8
I think if you were to order the switch tire then they will not rub on the slash.
Montigo is offline   Reply With Quote
Old 12-14-2008, 06:14 PM   #9
666
666's Avatar
LOL!!
I did, and that is what is on my Slash, I mounted the other tires up to see how well the Epic beadlocks held other tires. Can you read?
Old 12-15-2008, 03:57 PM   #10
Im also curious of this. I want to order some rears to mount my paddles.
z50_Jumper is offline   Reply With Quote
Old 12-15-2008, 04:33 PM   #11
does any one know if traxxas pede rear rims will fit on the front of the slash i know they work on the rear
Old 12-16-2008, 11:01 AM   #12
i have a set of the sand paws installed on the epic bead locks
im using them on my slash w/ a pl hardcorr body and im not getting any clearance issues
the main thing on installing the sand pawas on the epics is to take your time . when your screwing in the beadlock make sure to follow the star pattern and go maybe 2 or 3 full turns before going to the next one. because the rubber is so firm you can easily bend the beadlock ring if you dont take your time not only that but the tire wont mount eavenly no matter how much screw tightening you do
NeXt559 is offline   Reply With Quote
