01-17-2009, 04:51 AM | #1 |
Quarry Creeper Join Date: Oct 2005 Location: ELLENSBURG, WA
| Sidewinder/4600/Slash ?
Curious. What are you guys that run this combo set your breaks at ? Also, any drag break ? I've tried a couple of settings and get the feeling I have almost no breaking.
01-17-2009, 06:26 AM | #2 |
RCC Addict Join Date: Dec 2004 Location: HELL.....
drag brake no... but even regular brakes are useless with rwd at that speed
01-17-2009, 04:03 PM | #3 |
RCC Addict Join Date: May 2006 Location: Roseville
I am using a Velenion system in one of my Slash's. I have the brake set to about 60%. Enough to slow it down, but not lock up the rear tires. Was tired of stripping spur gears at every hard stop. Might get you in the ball park.
01-17-2009, 04:11 PM | #4 |
Sidewinder/4600 w/ no drag brake. I rarly use the standard brake, but I have it set at 75%. I tap it every once in a while to bring the noce down. |
01-18-2009, 12:31 AM | #5 |
Rock Crawler Join Date: Jan 2007 Location: Tuscaloosa
I run 0% drag brake and 30% brake. Anything higher than 30% with me and I end up locking them down and barrell rolling. No drag brake helps a lot with coasting into turns. That will help you get longer run times.
01-18-2009, 07:29 AM | #6 |
Ok, I'll go with 0 drag and 50 or 60 on brake for starters. One more thing. After changes are made via link, do I need to do anything with the radio or just go. I'm a lil new at electrics. I'm running a DX3R. In other words, I'm up and running, everything is set up ... I make a link change ... do I do anything on the TX after the change ? Thanx
01-20-2009, 09:01 PM | #7 |
Rock Stacker Join Date: Sep 2007 Location: Austraila, North Brisbane
Ok then i'm waiting on my 4600 kva motor an 4900mh 2cell Lipo to turn up, Now with the 4600, Mumba max and lipo What gearing should i have i've got the stock pinon, 16, 17, 21. and i think a 24 now i've got to run the standed spear gear cause i can't get them in Aus. I've look on hear and found every boby says something diffrent i don't want to disstroy a brandnew motor, speedy and battires.
01-20-2009, 09:10 PM | #8 |
I run mine with the stock gearing 18/86, but I have the 3500kv motor, you have the 4600, maybe go down a tooth or 2 to start on the pinion, or go up to the 90 on the spur.
01-20-2009, 09:35 PM | #9 |
Ok cool i think i'll start with the 16 and like caslte say if you can't hold your finger on the motor for more than 2sec gear it down.
