03-16-2009, 05:34 PM | #1 |
Pebble Pounder Join Date: Feb 2006 Location: San Marcos, TX
| Slash Shock Cap Problems...Suggestions?
After a few months of bashing, I have finally started popping the shock caps off the rear shocks. I have looked around on here and googled different stuff about it, but I figured I would go right to the source. What is the best thing to do about this problem? Aluminum shock caps? New shocks? What do ya'll think?
03-16-2009, 05:48 PM | #2 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
You could use either Traxxas 2667 aluminum Big Bore caps ($7.00 retail) or just upgrade to the Traxxas 2662 Big Bore shocks ($30.00 retail).
03-16-2009, 07:19 PM | #3 |
Rock Crawler Join Date: Jun 2007 Location: Great Britain
When the caps started popping on mine I went straight for Traxxas' Big Bore shocks. The alloy shock are far smoother and I've never popped a cap running them on my e-maxx. Well worth the extra cash. |
03-16-2009, 10:00 PM | #4 |
Newbie Join Date: Apr 2008 Location: Visalia
I to went right with the big bore shocks after blowing shock caps on a regular basis. I have had zero problems with them, high recomended.
03-16-2009, 10:03 PM | #5 |
Newbie Join Date: Jan 2009 Location: OKC 405
one of my shocks is doing that also i guess ill have to buy some big bore shocks too.
03-16-2009, 10:36 PM | #6 |
I wanna be Dave Join Date: Sep 2004
traxxas just released new shocks for the slash.
03-16-2009, 11:44 PM | #7 |
Forgot about that, IIRC they already have the variable rate springs in the pack!
03-17-2009, 11:50 AM | #8 |
Rock Crawler Join Date: Jan 2007 Location: Tuscaloosa
I went with just the aluminum caps and it fixed it on mine. I am running a 5700kv and took it off a 6 foot dirt bank. It'll bend a shaft but the top don;t pop off.
03-17-2009, 12:03 PM | #9 |
Quarry Creeper Join Date: Jul 2005 Location: Dirty South
03-17-2009, 12:11 PM | #10 |
i had the same problem rear shock caps pulling off. i simply screwed it back on, and took a zip tie and went around the cap where the threads are. never ever had a problem again. problem fixed for .01c and in about 1 minute and im pretty sure i jump my slash further than just about anyone here. has held up perfect, never failed again. |
03-17-2009, 12:44 PM | #11 |
03-17-2009, 03:10 PM | #12 | |
RCC Addict Join Date: May 2006 Location: Roseville
03-19-2009, 08:58 PM | #13 | |
point still applies though a .02c zip tie is a great fix. | |
03-19-2009, 09:55 PM | #14 |
I have done alot of things to punish the plastic shocks on my Maxx, and never once blown a cap. I've bent rods and rod ends, even snapped shock mounts. Once I sheared the entire left front suspension off and never spilled a drop of fluid, even with both shock rods bent back 90*. Are you sure you're not overfilling them? |
03-19-2009, 10:36 PM | #15 |
| My CHP buddy radar'ed me at 62mph when I hit my ramp. First pass I got hung up in a willow tree, second pass, did a few flips and when we measured it out from first impact to ramp, 61.5 feet. Wont do that again, was expensive to fix. |
03-19-2009, 10:44 PM | #16 |
My ramp was nicer than this one and I got a full speed run on the ramp before I hit it.. Went about as high as this guy, but twice as far. http://www.youtube.com/watch?v=9O2qJblce2E |
03-20-2009, 01:09 AM | #17 | |
03-20-2009, 01:22 AM | #18 |
Like a boss... Join Date: Feb 2008 Location: NorCal
Alot of what causes the shock caps to pop is the amount of flex the the stock shock towers have. It's great for durability but they flex so much that it will pull/pop the caps off. My advice is try a stiff shock tower, doesn't have to be all out aluminum. The RPM ones work great. Will help your problem a bunch. |
03-20-2009, 04:43 AM | #19 |
Quarry Creeper Join Date: Dec 2008 Location: other side of the track,the bad side
The integy ms9r piggybacks are working well for me, If you go this route thou I would recomend you use your stock springs and Invest in aluminum turnbuckles. |
03-20-2009, 06:49 AM | #20 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
The only time I've popped a cap off of a stock Slash shock was done by airing straight into a 4x4 about 4 feet off the deck at full throttle, trying to clear a double at a local track made for 1:8th nitro buggies. I filled it back up and threaded the cap back on and was back on the track in 15 minutes. Other than the shock cap popping off, nothing else was damaged. I could'nt believe it, after watching it fully T-bone a 4x4 dead-on. These trucks are tough! I don't know about the shock towers. I think the inherent flex is one factor that makes the truck as durable as it is. But there has to be some negative impact on the suspension geometry. Flex is good when absorbing an impact, flex is bad when you're trying to keep all the suspension components lined up and functioning smoothly. Im on the fence about buying a pair of fancy aluminum shock towers, cause I typically crash my Slashes pretty hard. I switched to some Integy piggybacks on the one Slash I've modded out. They look a lot better, but I'm not real sure if they're much of a performance enhancement... Last edited by Big Mike; 03-20-2009 at 07:02 AM. |
