06-21-2009, 02:19 PM | #1 |
Rock Stacker Join Date: May 2006 Location: Centerport
| Stampede Equal Length A-Arms
Out of the stamped, rustler, bandit, and slash are there any front and rear equal length a-arms? thanks
06-21-2009, 02:21 PM | #2 |
Rock Crawler Join Date: Jul 2007 Location: clearfield
They all use the same suspension. Are you looking to widen one? If so, google Wide-PEDE, or widening a pede/rustler...
06-21-2009, 02:41 PM | #3 |
Here's the deal made this sand pede for my bro and he didn't like it so i put i back to stock but now i want to make my own. Now i had put pede front rims on the front and back for the staggered look, but for mine i want the front end to be as wide as the rear with pede front rims on the rear. |
06-21-2009, 02:59 PM | #4 |
Quarry Creeper Join Date: Mar 2008 Location: Zachary
what? why would you put front rims on the rear? if you just put the front rims on the front and the rear rims on the rear then the front and rear are the same width |
06-21-2009, 03:12 PM | #5 |
i like the width with front rims on the rear arms so i want the the same on the front
06-21-2009, 03:57 PM | #6 |
Ok, get a pair of the rear lower arms... and put them on the front. You will have to put a couple washers on the hinge pin... ( inside the C of the arm)... the rear mounts are a bit wider than the fronts... You will be able to run the same offset wheels all around( i run all fronts). When you do this, you will have to make new upper links, and steering links.
06-22-2009, 11:35 AM | #7 |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
Read here, this website shows 3 different methods of widening a Stampede front end. http://www.stampedeproject.com/Traxx..._your_Stampede |
06-23-2009, 01:25 AM | #8 |
Newbie Join Date: Nov 2008 Location: Backwoods of Maine
Or, for a nice clean install, I have a set of ThunderTech Racing Extenda-Blocks made from Black Delrin. These give the front the same offset as the rear without changing suspension geometry, and beef up the front end in the process (these blocks are as or more durable than the RPM C-Blocks). I've actually been trying to sell mine for a while now, I parted out my TTR Stampede over a year ago... and these are the last item (aside from some small spare parts) that I have left. If anyone wants them, shoot me an e-mail: matthew.f.lambert@gmail.com -Matt |
06-23-2009, 03:15 PM | #9 |
buy some wideners?
06-23-2009, 03:41 PM | #10 |
Quarry Creeper Join Date: Nov 2006 Location: Reno
Ive seen some people use Jato arms on the front of Slashes to get a wider stance.
