09-27-2009, 03:44 PM | #1 |
Quarry Creeper Join Date: Aug 2005 Location: newport
| what ofna buggy is this, anyone know?
what ofna buggy, anyone? Thans for any help you can give. |
09-27-2009, 04:03 PM | #2 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
Looks like a Sportwerks? But I'm pretty sure it isn't! I'll try and look it up for ya.... Stripped down they all look the same!!!!
09-27-2009, 06:07 PM | #3 |
Quarry Creeper Join Date: Jan 2008 Location: Cyprus
That's a Hyper 7 with a cut servo plate and a weird centre diff top plate
09-27-2009, 09:02 PM | #4 |
Quarry Creeper Join Date: Oct 2008 Location: In the basement...
Someone has started / done an e-conversion...
09-28-2009, 07:58 AM | #5 |
thanks getting it in a trade. Should be here late this week. Yes, they had started, or did a brushless conversion to it at one time. I will make it brushless as well. I have most of the parts I'll need to complete it from previous projects. Just wanted to have an idea what it is incase I need anything. Thanks again. |
09-28-2009, 12:03 PM | #6 |
Hateraide Join Date: Dec 2008 Location: Mission BC
im doing the brushless to my 9.5violator |
09-28-2009, 03:54 PM | #7 | |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
If youre putting the motor in the rear passenger side of the car and plan on using a motor with a ribbed can like the Neu/Castle or Tekin motors you may have to grind down or relocate the rear chassis brace to achieve proper gear mesh if using anything under a 15t/16t pinion. Smooth can motors shouldnt cause any issues though. Im dealing with that problem right now on my Hyper 7. | |
09-28-2009, 04:25 PM | #8 |
Rock Stacker Join Date: Aug 2009 Location: Verwood, dorset, uk
those front upper arms don't look like the ones my 7 used to have and the shock towers look a little thinner. Also the chassis braces don't look like they're from a 7. But alot of parts are transferable between models and they're all very solid buggies. I broke very little on mine and what I did break was from running into 1/5th scale, both of us flat out and from a bad jump with tree interaction. So yeah, they're good and solid pieces of kit |
09-28-2009, 07:34 PM | #9 | |
09-29-2009, 10:07 AM | #10 | |
I may just make a brace from the rear housing to the center diff housing. More like an upper chassis plate. I have an ''xpro'' motor mount comming for it. I was going to make my own, but for 40 bucks including a battery tray I had to grab it. If the shock towers prove to be weak, I'll straighten them and double them up. This will be a basher, so a bit of extra weight isn't a worry. I'm going for more bullet proof basher than anything else for it. | |
09-29-2009, 08:16 PM | #11 |
Quarry Creeper Join Date: Nov 2006 Location: out in boonies!!
william, i've owned few ofna buggys and never had blue on hyper series but on 9.5 and lx series from onfa blue yes. hyper is from hobao and 9.5/lx is from different company but both sold under ofna as far i remember.good luck on your build. it may be lx one, go to ofna.com and veiw buggys for idea, i cant tell much by pics. |
09-29-2009, 08:51 PM | #12 |
RCC Addict Join Date: Feb 2005 Location: Minnesota
How many brushless buggies you going to have?
09-29-2009, 09:09 PM | #13 |
its acutally might be 9.5 violator like mine i will pull it out and double check for you
09-30-2009, 09:32 AM | #14 | |
| This will be my only buggy. I tradded my mudblaster for this to build as a beater for the warwick track. I need to be able to take 2 1/8th vehicles incase I break down. Quote:
Hopefully the motor mount will work that I have comming regardless of what it is. | |
10-09-2009, 07:54 AM | #15 |
10-09-2009, 09:51 AM | #16 |
looks like a lot of the parts from a ravenger From the ofna website it's the closest match, but not exact |
