08-27-2010, 11:58 AM | #1 |
Rock Stacker Join Date: Sep 2009 Location: Alberta
| Rc Tank ?
Sorry If this is in the wronge section. Ok so I just got a used "21st Century Toys" 1:9 M1A2 rc tank... (its huge and nearly 50lbs). The track is hard plastic and beacuse of that it doesnt grip very well. I was hoping to find a thin (1-2mm ish) sheet of rubber to glue on the track pads (I know ill have to periodically replace them but thats ok) but I cant find anything like that. Does anyone else have any ideas? I dont plan on using it alot but it will see outside.. I want it to stay pretty scale too. Thanks Tons |
08-27-2010, 12:11 PM | #2 |
Pebble Pounder Join Date: Jul 2009 Location: Calgary, Ab
Wrong section. Where in Alberta? If you're in Calgary, try Norwesco. They supply all sorts of wonderful plastic/rubber stuff for industrial use. They can get you thin sheets of neoprene, butyl, rubber, or even teflon if you want it. They fabricate sheet gaskets for our equipment all the time, so I imagine if you google for gasket suppliers in your town, you'll find one. |
08-27-2010, 12:39 PM | #3 |
Just outside Edmonton. Thanks for the info though Im going to do some calling around.
08-28-2010, 07:42 PM | #4 |
Just get a bicycle or car innertube and cut it up
