09-05-2010, 12:03 PM | #1 |
Quarry Creeper Join Date: Sep 2010 Location: t(._.t)
| Shortcourse 4-link vs. trailing arm
is 4 link on a straight axle better than trailng arm????
09-05-2010, 11:56 PM | #2 |
Rock Stacker Join Date: Feb 2010 Location: ashland
| trailing arm
i would shoot for the trailing arm as a shock is usually mounted there and creates a pressure point and needs to be extra rigid.Also will need to take some abuse from debris. But you'll still need a panhard bar or atleast a 2 link to keep it planted from moving side to side and to limit twisting and unwanted movement besides up and down travel
09-06-2010, 08:59 AM | #3 |
OK thanks |
09-07-2010, 06:26 PM | #4 |
Newbie Join Date: Oct 2008 Location: Ontario,Can
Even if you use trailing arms you still need to have a 4-link set up to keep everything in place with a straight axle. |
09-07-2010, 06:40 PM | #5 |
ur trailing arm is still bascially half a 4 link system lol just need the other points 2 more links or a panhard bar..then ur right back at a 3 or 4 link system
