Go Back   RCCrawler Forums > Miscellaneous > Non Crawler RC's
Thread: Camaro IROC-Z donkey hauler
Old 04-25-2011, 10:30 PM   #1
Default Camaro IROC-Z donkey hauler
Have had this bent up RC10 Gold pan chassis for a while and have been trying to figure out what to do with it. So I said what tha hell and chopped the rear and front off and reattached the nose piece. I still have to figure out where to put the tranny (gd-600), battery and the steering servo. Paint will be most likely Chezoom teal. Rear axle is a wheely king axle. Tires and wheels are off some traxxas vehicle, the front spindles are CRP parts so you can use 5mm ID bearings and tamiya wheels on the RC10
With body, I know the front wheels don't line up righ now, they did and will again, but the rear suspension wasa PITA to figure out and I had to change the lower mounts from a regular Wheely king to Crawler King ones
Top shot
Side view
There wont be a front shock tower, due to clearance issues, so I just used a piece of piano wire to act as a spring. I still need to add upper links though. I'llprobably just drill some holes in the side of the chassis for the steering rods to go through to the knuckles. Rear body mount will most likely be a Stampede rear and front a front. I thought about putting the motor up front, but dont think I'll have anough space
Gula is online now   Reply With Quote
Old 04-26-2011, 12:08 PM   #2
~THE SCALE SHOP~
SWEET! CANT wait for more
STANG KILLA SS is offline   Reply With Quote
