04-24-2012, 04:15 PM | #1 |
I joined the Band! Join Date: Feb 2012 Location: bay area
| My lcg Slash 4x4
I Built up my slash 4x4 on sunday with some new parts. -SSC LCG chassis -Traxxas esc fan -11.1v 3s lipo -STRC Bellcrank kit- in the mail I broke a rear axle shaft today and ordered MIP xduty cvds just now. Last edited by 707offroad; 04-24-2012 at 04:33 PM. |
04-24-2012, 04:56 PM | #2 |
Quarry Creeper Join Date: Jul 2009 Location: Back from vacation!!!
| Re: My lcg Slash 4x4
My 2WD LCG- STRC LCG kit, Rustler Chassis, Anza C/F towers and mounts, RPM Arms, TRX Alloy Caster blocks, STRC Alloy rear carriers & bulkheads, 4X4 Bellcrank, RPM front hubs, MIPs , AKA Re-Bars, Big-Bores, 3900 kV Castle, Dyna rear sway and more stuff I've probably forgotten about..... |
04-24-2012, 05:45 PM | #3 |
Here's some of my pos collection
04-25-2012, 12:17 AM | #4 |
I've got a 150a hobbywing esc and a brushless saker 36x74 3490kv 4 pole motor that I'm thinking about putting in this truck It stripped the rear differential and ring and pinion in the first 5 minutes on my 1/8 buggy so hopefully it doesn't do the same to my slash Last edited by 707offroad; 04-25-2012 at 12:22 AM. |
04-30-2012, 02:49 PM | #5 |
I installed the MIP axles over the weekend... what a pain in the ass! One of the axles shafts is funky and causes thrashing and makes the a-arm and diff wobble real bad. Are the MIP axles suppose to have the pins in phase like car driveshafts?
05-02-2012, 05:10 PM | #6 |
Newbie Join Date: Apr 2012 Location: Portland
| Re: My lcg Slash 4x4 I just put those in my Stampede, they are actually easier to use than they seem. Which pins did you use in the outer CV?
05-02-2012, 05:31 PM | #7 |
I used the supplied roll pins for the outers. Last night I took apart the shaft that was thrashing and found excess loctite was causing binding in the joint. My mistake |
05-02-2012, 05:56 PM | #8 |
The part that was a pain was installing the spring steel roll pins. As for the cvd pins mine had flat in the center for the set screw
My lcg Slash 4x4 - Similar Threads | ||||
trce lcg slash 4x4 | c0bra | Non Crawler RC's | 48 | 02-16-2012 07:16 PM |
lcg slash 4x4 | c0bra | Non Crawler RC's | 4 | 10-07-2011 01:23 PM |
