08-25-2014, 05:31 PM | #1 |
Quarry Creeper Join Date: Jun 2011 Location: Walnut Grove
| help to size a prop
so i have a 30cc ryobi 2 stroke engine i want to put on an airboat. how would i size the prop for the power. i can find charts and stuff on nitro engine but none on gas. id imagine a gas engine does not make the power a similar size nitro engine would make. any help is appreciated |
08-25-2014, 05:46 PM | #2 |
| Re: help to size a prop
You are going to need a thrust stand to figure out the best prop for your motor if no data is out there. Or you could use the nitro charts and see how the rpms compare. If you aren't hitting the target speeds then reduce pitch or diameter.
08-25-2014, 06:12 PM | #3 |
would a hobby shop like hobbytown have a thrust stand?
08-25-2014, 06:45 PM | #4 |
Nope, you would need to build one. Basically just a mount that pushes on a scale.
help to size a prop - Similar Threads | ||||
CR01 Prop shaft question | raceeng18 | Tamiya CR-01 | 7 | 06-21-2012 09:37 PM |
Prop shaft options??? | Highlucks | Tamiya CR-01 | 3 | 08-19-2009 09:10 PM |
tamiya prop shaft e-ring | sierradmax | 2.2 Scale Rigs | 0 | 12-14-2008 05:53 PM |
