Go Back   RCCrawler Forums > Miscellaneous > Non Crawler RC's
Thread: Tamiya TA01/TA02 79 F150 Trail Truck
Old 01-14-2016, 12:09 PM   #1
Default Tamiya TA01/TA02 79 F150 Trail Truck
I decided to try and use up some parts I had laying around and convert and older Tamiya TA01/TA02 into a trail rig. I'm using an HPI 79 Ford F150 body as the basis for the wheel base.
So I took some measurements and extend the rear of the chassis with some flat aluminum.
Trying on the body and wheels after extending the chassis:
Mocking up some Proline bumpers I had laying around and an RC4WD light rack:
Then I started playing with the body mounts and ride height. I also was playing around with a lexan underpan in an effort to conceal some of the chassis, not sure yet if I will use it or not:
Xporter is offline   Reply With Quote
Old 01-14-2016, 06:44 PM   #2
Default Re: Tamiya TA01/TA02 79 F150 Trail Truck
This takes me back to the good ole days of making scale trail rigs out of whatever we had
chuckatruck is offline   Reply With Quote
Old 01-19-2016, 07:30 AM   #3
Made up the front bumper mount and body post/mount from some old Traxxas parts I had in the bin:
Also put some paint down on the the body, need to finish trimming and apply decals:
Old 01-25-2016, 03:38 PM   #4
Look in good
Sent from my LGLS990 using Tapatalk
Old 01-25-2016, 05:59 PM   #5
Shouldn't this be in one of the scale sections?
Goatman4rc is offline   Reply With Quote
Old 02-03-2016, 07:01 AM   #6
Update:
I worked on strengthening the front bumper since it was attached to the flimsy Tamiya plastic bumper. I can now pick the truck up by the front bumper without it trying to pull away from the body.
I then figured out a way to put some Axial sliders on the chassis.
I mounted the body with magnets gooped to the body and countersunk screws into the body post up front. In the rear I just used the traditional body post holes and clips.
I'm still needing to trim away the bumpers from the actual body and apply decals. I was going to start with the decals last night but the decal sheet that came with the body was precut wrong and it cut a line through some of the decals. I have contacted HPI to see if I can get a replacement sheet.
Old 02-03-2016, 06:36 PM   #7
snapon boy's Avatar
Very nice work
snapon boy is offline   Reply With Quote
Tamiya TA01/TA02 79 F150 Trail Truck - Similar Threads
Axial scxtr or Tamiya F150 stadium 4wd truck TCBronson Newbie General 5 01-02-2010 10:46 AM
TA01 or TA02-Which is more versatile? Sasquatchbagger Chit Chat 4 03-19-2008 02:52 AM
Tamiya F150 stadium truck scruff007 1.9 Scale Rigs 19 02-28-2007 02:22 PM
