12-15-2017, 02:13 AM | #1 |
Quarry Creeper Join Date: Sep 2012 Location: middle of nowhere
| Overhead Crane Build
Not sure if this fits or what kind of interest it will have, but it will be RC! Also very impractical. I’ve had this idea for a while, I actually started accumulating parts a while ago and have a large stash of previously scrounged goodies that I hope to use. So basically I want to build an RC sized overhead crane. Said crane will ride on a track suspended from the ceiling in the small shop attached to the garage. (My Man Cave) As of now the track is looking like it will be made of 1-1/2” box tubing. I would really like to make it out of 80/20 but it’s a more expensive than I can really justify and I have the box tubing already. I’m not sure how big I am going to go yet, I’m hoping for about 19’ long tracks about 12’ apart. Keeping the unit tracking nicely and not binding is my concern I may not be able to go that wide. I’m thinking of about a 20-30lbs lifting capacity. Not a lot but it should easily lift any RC I have and anything they can carry themselves. The unit itself will be fairly heavy and could probably lift a lot more but the structure of the building would eventually come into play so 20-30lbs it is. This could very well be a pretty slow build but hopefully this thread will keep me going on it when life gets busy. So anyway enough yackin... Here is where I’m currently sitting. I have the end trucks started. The project will use a lot of skateboard/roller blade wheel bearings since they’re cheap. Bearings will be inserted into the bores on the ends and captured with screws and nuts. I was going to tap the small holes for 3mm screws to capture the bearings (3 from each side) but I messed up and the only way to save the parts was to clearance drill the holes and use nuts. The square pockets will receive aluminum blocks that box tubing will slide over and bolt to, to create the bridge rails. I’ll post updates as I make more progress! |
12-15-2017, 10:06 AM | #2 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: Overhead Crane Build
Love it, I'll be watching this one..
12-17-2017, 10:29 AM | #3 |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
Im in.
12-18-2017, 10:47 PM | #4 |
| Re: Overhead Crane Build So over the weekend I was able to mill out the blocks that fit into the pockets of the end trucks. The blocks are 2” OAL and the pockets are .125” deep. The blocks are held in with 6mm SHCS. I milled the blocks .001” smaller per side than the pockets. (.002” total clearance) This will help keep them square to the end trucks and hopefully keep the box tubing that will slide over the blocks square as well. I realize I will be at the mercy of how straight the box tubing is and this was probably unnecessary. The other 6mm tapped holes will fasten the box tubing to the end truck assemblies. I don’t recall what the clearance is between the tubing and the blocks, I measured it all a few months back and went off my notes and drawings. Hopefully it all fits!! I also forgot to mention the large cylinder is a solid bar with an eye bolt that weighs 20lbs on the nose. This is my test weight for when I get farther in the project and need something to lift. The beer can is for scale...and to get under the skin of the beer snobs. |
01-05-2018, 11:31 AM | #5 |
| Re: Overhead Crane Build Well I finally had a little time to work on the crane. I turned the roller wheels and axles and got them mocked up. For now the wheels are just plain steel, I may have to add some groves for o-rings if they don’t provide enough traction. The bearings are 8mm bore roller blade/skate board bearings. I haven’t decided if I like the nuts or cap screw side out yet. The bore in the end trucks is a tight slip fit with the bearing OD. I plan on using two traction motors driving one wheel per end truck. The axle shafts will mate to Traxxas Summit center shafts and then to the gear motors. Only two axles need to mate up to the traxxas shafts but I turned all 4 axles the same in case I need to use 4 traction motors for whatever reason. |
01-05-2018, 11:59 AM | #6 |
Have you mentioned what rails you will use? Will there be a winch?
01-05-2018, 12:22 PM | #7 |
Pretty looking build so far. I loved machined metal. |
01-05-2018, 12:38 PM | #8 |
| Re: Overhead Crane Build |
01-05-2018, 12:41 PM | #9 |
Overhead Crane Build - Similar Threads | ||||
Overhead Shop Camera Trolly Project | Harley | Videos! | 0 | 07-15-2013 11:44 AM |
Overhead (or underneath) Pic of 380 vs 540 motors | JKMotorsports | Redcat Crawlers | 6 | 02-10-2012 10:04 PM |
Crane Cams is No More | Shaun | Chit Chat | 20 | 03-26-2009 06:50 AM |
For those of you looking to build a crane... | Rudukai13 | Chit Chat | 0 | 10-31-2007 11:55 PM |
