06-13-2015, 10:12 PM | #1 |
Quarry Creeper Join Date: Apr 2013 Location: Upstate
| Frashier's Funpark - Team Challenge - June 28th, 2015
What - Frashier's Funpark - 2 Man Team Challenge When - Sunday, June 28th, 2015 Where - 556 Jack McKinney Road, Forest City, NC 28043 Driver Check-in will be at 8:30 - 9:00am following with a Driver's Meeting.. Would like to get it started by 9:30, there will be a lot of ground to cover. We will do the Bonus course after lunch, following up with the prizes! LUNCH - Doing the usual Lil Caesar's run, please bring 5$.. 2 Man Team Challenge - Will be running in teams of 2, and running ALL three classes (C1-C3)! Choose your teammate wisely, it will play a large role in this event. If you are not able to find a teammate we will pair you up on event day. We will have 3 (25) courses along with a bonus course, they will all be timed! The team with the lowest score will be taking home the good stuff.. This will be ran SORRCA style, with the exception of a few rules. This will be discussed in detail on June 28th.. SORRCA.com |
06-13-2015, 10:13 PM | #2 |
| Re: Frashier's Funpark - Team Challenge - June 28th, 2015
*Reserved*
06-15-2015, 04:33 PM | #3 |
Rock Crawler Join Date: Mar 2006 Location: Benson,NC
Sounds interesting to me. What will the admission price be?
06-15-2015, 06:42 PM | #4 |
| Re: Frashier's Funpark - Team Challenge - June 28th, 2015 |
06-15-2015, 07:12 PM | #5 |
Sounds good man. Little over a 4 hr drive for me but I will try to make it out. Thanks for putting it on for everyone.
06-15-2015, 07:56 PM | #6 |
06-15-2015, 11:01 PM | #7 |
Quarry Creeper Join Date: Feb 2006 Location: Angier N.C.
I'll try and make the drive also.
06-16-2015, 12:36 PM | #8 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
I would recommend to any of the NC guys to try and make the trip. We have a great group of guys and gals in the CSC.
06-20-2015, 06:49 PM | #9 |
Pebble Pounder Join Date: Apr 2011 Location: State Road N.C.
Does both members of a team need to drive the same kind of class rig or can it be a mixed team?
06-21-2015, 06:40 PM | #10 |
| Re: Frashier's Funpark - Team Challenge - June 28th, 2015 Your team needs to consist of the same class vehicle for C1. Might be an exception for C2/C3 considering we use the same gates. It will be discussed in detail the day of the event to see what everyone wants to do. Thanks! Last edited by wilbywise; 06-21-2015 at 06:42 PM. |
06-22-2015, 01:36 PM | #11 |
Fair enough , add two to your list for Sunday |
06-23-2015, 03:51 AM | #12 |
Well MIPS are coming in the mail from rpp. Had to send my one piece output gear for my trans to be drilled for through bolts. So that being said hopefully everything will arrive and have time to install before Sunday.
06-24-2015, 06:37 PM | #13 |
| Re: Frashier's Funpark - Team Challenge - June 28th, 2015 Nice! Make sure and use a dab of the blue loctite that comes with it, let it sit for a 12-24 hours if you can.. Or if your in a time crunch just make sure its snug when in between runs or every so often. I've seen a lot of people lose MIP parts the first few minutes of owning/running it! |
06-25-2015, 03:09 AM | #14 |
If you are running big HP use red loctite.
06-26-2015, 03:20 AM | #15 |
I am running MMP and tekin roc412 3100kv on 3s. Would that be considered big power? Not a big fan of the red to tell the truth, always have trouble getting something back apart after using it.
06-26-2015, 04:41 AM | #16 |
Yep that's big HP and torque. You'll be glad that you put the red on believe me. I run the mmp and pro4.
06-27-2015, 03:23 PM | #17 |
Everything has arrived, looks like I will see you guys in the morning |
06-27-2015, 04:20 PM | #18 |
I will be running class 2 should have a friend with a class 2 rig with me.
06-27-2015, 04:34 PM | #19 |
Rock Stacker Join Date: Feb 2013 Location: Asheville
If you don't have a partner, you will get paired with someone at driver check in
Frashier's Funpark - Team Challenge - June 28th, 2015 - Similar Threads | ||||
2015 RC4WD Scale Challenge Series - New Castle, PA (August 28th-30th) | Rckcrwlr | Competitions | 833 | 07-15-2016 09:59 AM |
Frashier's Funpark - Team Challenge - June 28th, 2015 | wilbywise | South Carolina | 75 | 07-01-2015 07:01 PM |
2015 Team KNK Top Truck Challenge | GiJoe | Team Losi Comp Crawler | 1 | 06-09-2015 01:06 PM |
Team KNK Hardware "Buddy Run" June 28th 2014 Lebanon Ohio | Team KNK | Competitions | 1 | 06-29-2014 12:56 PM |
