03-04-2008, 09:55 PM | #1 |
Rock Stacker Join Date: Sep 2004 Location: Orangevale
| Grappler help
I just got done painting my Grappler body. I just mounted it on my AX10 it looks good. But my proble is that I am going to have to do alot of trimming so the tires do not rubb. How much is every one haveing to trim on there grappler bodys?
03-05-2008, 12:02 AM | #2 |
Quarry Creeper Join Date: Nov 2007 Location: Jamestown
you should put the body on, set it flat and put each wheel to full articulation, you will see where the tires rub on the body, then just trim as needed. It all depends on how low you mounted your body on the chassis, the lower the body the more rubbing you will have.
03-05-2008, 04:16 PM | #3 |
Rock Crawler Join Date: Dec 2007 Location: Maple Grove, MN
I just got my grappler on.. Used the mounting holes that are pre-set on the body, and do not seem to have any rubbing. Must be the way my AX-10 is set up.
