03-17-2008, 12:51 AM | #1 |
Newbie Join Date: Mar 2008 Location: canada
| newbie question
how do you draw in the lines on a body......is there a trick to it so that it looks nice and clean. thanx
03-17-2008, 01:21 AM | #2 |
sorry i forgot to mention i am using spray can....
03-17-2008, 05:26 PM | #3 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
Do you mean guidelines for cutting the masking? Or do you mean lines on the exterior? Need more info to help on this I guess. Most bodies have a clear protective/overspray film that you can draw on. After you mask the inside you use a BRAND NEW NO. 11 X-Axto blade and simply follow the exterior lines from the inside. For making straight cuts on the inside of a body I use a scrap piece of lexan that I have cut with a straight edge. You can conform it and also trim it to fit tight areas for a straight cut. |
03-18-2008, 12:23 AM | #4 |
well i want to draw in the lines for the doors and window kinda of thing i try to do it on one body and it looks horrible...........just wondering if there's a special way to do it |
03-18-2008, 10:04 AM | #5 |
Rock Stacker Join Date: Feb 2008 Location: marshalltown
I usually just use a sharpie and take my time.
