05-28-2008, 08:41 PM | #1 |
Pebble Pounder Join Date: Apr 2006 Location: Grand Rapids
| tan?????
does any one know how to mix up tan? i have pactra racing finish paints. thanks.
05-29-2008, 09:04 AM | #2 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
I used fascolor tan a while back with great results. That doesn't directly answer your question, but it does get another shot of my tan bug out there. |
05-29-2008, 10:22 AM | #3 |
Newbie Join Date: Feb 2008 Location: Netherlands
No mixing needed with Tamiya PS31 smoke lolycarbonate spraypaint... Used a couple of times, just apply 3 or 4 layers and you'll be fine Greetz Jim |
05-29-2008, 03:56 PM | #4 |
Quarry Creeper Join Date: May 2008 Location: malvern
You should be able to mix brown and white and get the color you want.
06-01-2008, 09:58 AM | #5 |
I wanna be Dave Join Date: Dec 2007 Location: Florida
you can mix red and green if you have it then add white to lighten it up...
06-02-2008, 12:48 PM | #6 |
Rock Crawler Join Date: Aug 2004 Location: Saugus
I've used model masters modern desert sand painted on the outside with great success. |
06-06-2008, 01:19 AM | #7 |
Newbie Join Date: Feb 2008 Location: I.E. 909
| Answer to the tan question Here it is. Spray white pearl on your body. Dispite the fact it says white, it will come out clear. Depending on how light you want your tan to be, will depend on who many coats fo pearl you put. After your pearl, hit it with your brown. Also, make sure to use a hair blower when drying your coats. When your done by pulling the outside film, watch your tan appear. Good luck |
06-06-2008, 07:10 AM | #8 |
RCC Addict Join Date: Jan 2008 Location: www.rccrawler.com
