07-28-2008, 03:04 PM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: New Zealand
| Body joins
I have cut an shut a body and the lines are almost perfect where they join, I have glued the inside with with lexan but now i'm stumped as to what you guys use to make the lines on the outside look good. Do you use a filler ? If so does it need to be a flexible filler ? Any help appreciated please
07-28-2008, 07:16 PM | #2 |
Rock Crawler Join Date: Jan 2007 Location: Lehigh Valley
I used white putty for models that I found at the LHS.
07-28-2008, 09:23 PM | #3 |
07-29-2008, 01:28 PM | #4 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
You said you "have glued the inside with with lexan" - is it a clear lexan body, or is it a "hard" body, like a Clod or Hi-Lift? If it is clear, you wouldn't want to use an opaque white putty. Maybe just a thin bead of Shoe-Goo smoothed into the joints.
07-29-2008, 04:29 PM | #5 | |
07-30-2008, 03:35 AM | #6 |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
shoo goo
07-30-2008, 03:51 AM | #7 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Shoe goo if the body is lexan. Filler if the body is styrene. |
