Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Tire tread paint masks?
Old 11-04-2008, 04:37 PM   #1
Default Tire tread paint masks?
Ok I have a new body on the way & am using the gatecrasher so with the surface area on the roof I wanted to do something different but I am not able to find a mask or transfer sheet with tire treads.
I want to have a few diff patterns crisscrossing eachother. Like Krawler, Bogger & TSL patterns.
Please let me know if you have any ideas?
tubed-n-lubed is offline   Reply With Quote
Old 11-04-2008, 04:48 PM   #2
Besides spending 20+ hours with my xacto & a roll of tape
Old 11-04-2008, 05:23 PM   #3
paint a tire and roll it across the inside of the body still wet?
hairba11 is offline   Reply With Quote
Old 11-04-2008, 05:27 PM   #4
Well my idea was 20 hours with an x-acto and tape but I like the painted tire idea better. Altho you may get more satisfaction from the 20 hours....
1rcmonster is offline   Reply With Quote
Old 11-04-2008, 05:38 PM   #5
That was the first thing I thought of & tried it inside an old body........... it didn't workout so well because of the contours.
This is what I was thinking of:
& after looking at it like this I think that it would be more than 20+ hours! I may be my sanity as well!
Old 11-04-2008, 06:00 PM   #6
well, I figured pressing the tire into the contours would make it look like it had been driven on, but for using it as a patttern, it looks like a lot of exacto work unless you know someone with a vinyl graphics cutter to make a mask for you
if nothing else, you could print a pattern out, tape it to a roll of masking tape with scotch tape, cut out all the detail, then use the masking tape as a stencil?
found a couple of source pics
Old 11-04-2008, 10:09 PM   #7
kevin107 on here has a plotter.
twisted is offline   Reply With Quote
Old 11-05-2008, 01:08 AM   #8
I have a guy that does vinyl signs in town & have used him before for a window banner that I took him on cd, I will stop by & see what he could cut for me & if not I will have mike do it.
