11-07-2008, 05:51 PM | #1 |
Rock Stacker Join Date: Sep 2008 Location: Winston-Salem, NC
| need some painting tips
can anyone give me any tips on how to make a granite rock looking paint job? i've had this idea for awhile but just now getting around to actually possibly applying to a body.
11-10-2008, 08:48 PM | #2 |
RCC Addict Join Date: Jun 2008 Location: Fresno
take the colors you want as the particles and spray a very light coat through some sort of mesh (i used some mesh made for a screen door) then lay down ur main color *note ive done this to paint the doors on my work bench at home and not sure how well it will work on a lexan body |
11-10-2008, 09:31 PM | #3 |
thanks for the tip. i'm planning on trying this on a spare betty body i have laying around.
10-15-2009, 05:48 AM | #4 |
Rock Stacker Join Date: Mar 2009 Location: k falls
| ganite paint
what about using that stuff that comes in a can that you can spray on wood to make it look like granite..... im going to try it on my blazer for my canopy to give it that zolatone look....:-P
10-15-2009, 06:29 PM | #5 |
Quarry Creeper Join Date: Jun 2004 Location: aurora, CO
its a little on the advanced side.... but you'll get some great tips!!!! http://www.airbrushaction.com/videos...erry-hill.html its done on a shirt so all you need to do is work back from wear he ended. sooo that would be first you highlights..... to balck... to shading the stone then start some speckiling and finishe off with some more shading and some color streaks and back with grayish blacking blueish color or what ever! should be pretty simple! |
10-15-2009, 07:48 PM | #6 | |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
10-15-2009, 07:53 PM | #7 |
ahhh good question! that was a clothes pin! you can you any other small flat peice of material but the porus nature of the wood works really well for holding paint for teh spatter. you can also turn your airpressure down low and actually pinch off your air supply at the line, pull the trigger a few times to flow some paint and let go of the hose slightly if you do this over and over and develop a rythm you can splatter with no clothes pin!
10-21-2009, 08:28 PM | #8 |
Newbie Join Date: Oct 2004 Location: Harrisburg
How about the Hammerite spray, not sure what surfaces it sticks to though?
10-21-2009, 08:40 PM | #9 |
Quarry Creeper Join Date: Oct 2008 Location: Spanaway, Wa
Use a paintbrush loaded with the color of the granite "speckles" and "flick" it on the body....same goes for the other color of speckles....as granite has various shades...
