11-26-2008, 08:50 PM | #1 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
| ? How to remove paint ?
How can I remove paint from a hard bodies window? I want to make sure I do it right, I know some chemicals will turn the window, or ruin it. Thanks Tom |
11-28-2008, 08:20 PM | #2 |
Anybody have an idea??
11-28-2008, 09:22 PM | #3 |
I wanna be Dave Join Date: Jul 2006 Location: Moscow Mills MO
I use ez off on the body, but never on the clear parts. sorry bro, hope you figure it out. |
11-28-2008, 11:01 PM | #4 |
Rock Crawler Join Date: Nov 2006 Location: Spanish Springs, Nv
I think you would be able to use the same stuff as you would use on lexan.
11-29-2008, 07:14 AM | #5 |
support@rc4wd.com Join Date: Nov 2007 Location: Lancaster, Ohio
Brake fluid, I do believe does the trick. Someone back me up on that though.
11-29-2008, 07:20 AM | #6 |
id be careful on the windshields, smoked or clear types, it may leave swirl marks if it doesnt eat it. could try Purple Power or Castrol Super Clean degreasers, safest on hard plastics. |
11-29-2008, 10:16 AM | #7 | ||||
I'll try some purple power. It didn't do anything for the body, but might for the glass. Thanks guys! | ||||
11-29-2008, 11:35 AM | #8 |
Quarry Creeper Join Date: Jul 2004 Location: Deland
I had a vintage Brat body that had paint on the glass, what I did was sand it off with 1500 grit sandpaper and then airbrushed clear enamel over it (don't use laquer it has a chance of yellowing a clear, but since you windows are smoked it should be fine, but I would use enamal just in case), after the paint dryed for about 2 weeks I used an automotive polish. looked pretty good. the longer you wait with the polish step the better, to let the paint fully cure (minimum 2 weeks, a month would be better). I have always shyed away from any chemical stripping on plastic. Last edited by flatfender; 11-29-2008 at 11:38 AM. |
