| | #1 |
| Newbie Join Date: Nov 2008 Location: Utah
| Ya i was just wondering my body should be here today so im going to paint it. My question is its in the low 40's here and i know with most painting it has to be around 70 degrees in order for it to turn out. Have any ideas how i can paint my body without having to wait till Spring. Thanks |
| Sponsored Links | |
| | #2 |
| ......../-__-\........ ![]() Join Date: Nov 2007 Location: Memphis
| paint indoors |
| | #3 |
| I wanna be Dave Join Date: Nov 2008 Location: In the shed with the People Eater.
| Basement, attic? Rent a commercial van and run the heater. |
| | #4 |
| Choppin' it up. ![]() Join Date: Oct 2007 Location: SW Arkansas
| You can also put the paint and body indoors til they reach room temperature. Then go paint outside or garage. And then I lightly use a hair dryer on the newly painted body. I've painted in about 50 degree weather in my garage with room temp stuff and didn't have any problems using the method above. But then again, I can sometimes ghetto-up some stuff. Just my .02 |
| | #5 |
| Rock Crawler Join Date: Sep 2008 Location: N.E. Mpls
| Check with local industrial places with a loading doc or wharehouse. Many times if ya ask the guys in back they might let ya. Just fill them with gab and tell them about the hobby,you might get a running partner... High schools are another possible. I would not recomend painting in the basement tho something about flamable fumes and that water heater right over there???...Something about the pilot light... Whooda thunk??? |
| | #6 |
| Quarry Creeper Join Date: Aug 2007 Location: right above my feet
| i keep all supplies in the house, and paint in the garage. It's in the 20's here now, and with a heatgun after each light coat, and keeping the can of paint warm, it works fine. I airbrush in the basement, which is usually in the high 50's in the winter without any problems. |
| | #7 | |
| | #8 |
| Thanks for all of the information i will go buy some paint and make sure everything is room temp then paint it in my garage. Thanks a bunch |
| | #9 |
| | #10 |
| Moonbuggy Berg ![]() Join Date: Jul 2008 Location: Chula Vista
| You could also right before you paint put the rattle cans in hot water just enough to warm the can. This has worked for me. Just another option |
| | #11 |
| RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
| Rattle can or AB? Rattle just warm it in water for a few minutes. That helps the propellant out. AB has no propellant in it but you could warm it if needed. I paint year round inside no issue. I use my spare shower and layer it with newspaper and paint away. |
| | #12 | |
Thanks | |
| | #13 |
| Team T1E/VP Driver ![]() Join Date: Feb 2008 Location: High Point
| What about using a space heater to warm the garage up and then cut it off before painting. My father is a paint contractor, and we use to do this to spray cabinet doors all the time... as long as its all warm before taking it out there...if you can get the garage up to temp... should last you a few coats for sure! |
| | #14 |
| Ya i was also thinking of going that way except do you think a space heater would warm up a whole garage. Because if i do it that way i will probably just buy a cheap space heater from wal mart |
| | #15 |
| Pebble Pounder Join Date: Apr 2008 Location: yakima
| put the can in some warm water and hurry when you get outside. you can warm up the body too if you want. |
| | #16 |
| Rock Crawler Join Date: Mar 2008 Location: lodi
| does the cold have any effect on window masks? when i paint i tend to make the mask peel as it is i dont knwo why but ill keep looking for that answer hahaha the search button is my friend |
| | #17 |
| What i suggest for the window panels is to wash your hands real well then take your finger nail and run it around the outer edge. I do this whenever I paint a body and they do not even come off when I put painters tape on them to do a two tone body. |
| | #18 | |
x2... and also put the masks on in the warm, and make sure the body is good and clean before you do that. I would let it set up a little while too before taking it to the cold or cooler area just to be on the safe side. | |
| | #19 |
| Newbie Join Date: Aug 2008 Location: Indianapolis
| I can remember back in the 70's painting a Dodge in zero degree weather in the garage using electric heaters. An added benefit was saving money on drugs that night, quite a high. |
| | #20 |
| Okay i painted it today, i will post up some pics either tomorrow or monday. I used a hair dryer and warmed up the body and then ran outside and hurry and painted on a coat, and basically did that like 5 times I was also wondering if anyone has some tips on drilling out the body post holes, also any tips on cutting out the body would be much appreciated. I bought some body scissors when i bought my body so those should come in handy. Thanks |
| Thread Tools | |
| Display Modes | |
