Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Paint and Body
Thread: Will this brake fluid work?
Old 12-10-2008, 08:28 PM   #1
Default Will this brake fluid work?
For removing paint from a lexan body? It's Pennzoil Dot 3 and Dot 4 Brake Fluid.
Calicrawler23 is offline   Reply With Quote
Old 12-10-2008, 09:48 PM   #2
It will take paint off real cars!
SDheavymetal is offline   Reply With Quote
Old 12-10-2008, 10:05 PM   #3
test it on some scrap lexan and see what happens...... i've always used 1:1 paint thinner and water
crawlin4evr is offline   Reply With Quote
Old 12-11-2008, 03:34 PM   #4
the only problem with that is the oil will penatrat the body and then the paint wont stick.
GTIMM74 is offline   Reply With Quote
Old 12-12-2008, 08:11 AM   #5
Default I've Been Using Brake Fluid For Years . . .
I have been using brake fluid to strip lexan bodies and other painted parts for years.
Buy the cheapest brake fluid you can find - you will not be able to reuse it. It all works . . . Dot 3, Dot 4 . . .
After you have removed the paint with the brake fluid, just remember to wash the body with warm soapy water and some JOY dishwashing liquid (or similar hand-safe dishwashing liquid), dry and wipe with denatured alcohol before you repaint.
I also use a non scratch scrubby sponge when I do the water/dish soap wash.
John
jrabenius is offline   Reply With Quote
Old 12-12-2008, 10:56 PM   #6
Thanks guys,
No more posts needed.
