Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Paint and Body
Thread: Masking tips and tricks
Old 12-12-2008, 09:41 AM   #1
RC4WD TEAM DRIVER
Tomy's Avatar
Default Masking tips and tricks
I'm about to paint my first body. I've been practicing on coke bottles trying different masking tapes. So far the results haven't been satisfactory. I've had a lot of bleed through and I'm not able to achieve sharp lines.
So how do you mask a narrow and sharp line around the windows for example? I haven't tried a liquid mask yet. Is that the way to go?
Thankful for tips, as I want to get at least a decent result.
Tomy is online now   Reply With Quote
Old 12-12-2008, 09:59 AM   #2
~The Scale Shop~
STANG KILLA SS's Avatar
MASKING tape is junk.
get your self a good quality vinyl or pinstripe. then youll have crisp clean paint breaks with 0 bleeding.
STANG KILLA SS is offline   Reply With Quote
Old 12-12-2008, 10:10 AM   #3
Practicing my launchs >:)
Robbob's Avatar
yup skip the masking tape, if it doesnt bleed then youll have rough edges if not even paint build up around them.
personally i use Liquid Mask for years. a new x-acto blade, a steady hand and not much pressure it works out great.
Robbob is offline   Reply With Quote
Old 12-12-2008, 10:13 AM   #4
Won't you mark the lexan with the exacto blade cutting out the liquid mask?
goldmember is offline   Reply With Quote
Old 12-12-2008, 10:14 AM   #5
Try "FROG" masking tape. It is a new product sold in the paint dept. at Home Depot. Basically is the same as traditional blue mask, only the adhesive is 100% better. I use this tape on my bodies, IMO it works as well as vinyl at half the cost. Leaves sharp clean lines, easy to score/cut, easier to get into those tight spots.
RockAddict75 is offline   Reply With Quote
Old 12-12-2008, 10:17 AM   #6
RC4WD TEAM DRIVER
Tomy's Avatar
Sorry, but I'm not sure what you mean with vinyl. Any links to a web page?
Thanks!
Old 12-12-2008, 11:05 AM   #7
Robbob's Avatar
not if you dont press hard, with a sharp blade you can cut the mask without knicking the lexan.
use to do nascar replicas in the oval days before vinyl printers came down in price, never had a fender fall off using a blade.
Old 12-12-2008, 12:30 PM   #8
Good to know thanks!
Old 12-13-2008, 02:12 PM   #9
I use automotive green masking tape. It has a low stick to it and it leaves real clean lines and you can get it for like $2.50 a role they have wide and narrow works great
MonsterAnt is offline   Reply With Quote
Old 12-13-2008, 09:46 PM   #10
To mask a window off on the inside of the body, lay your masking tape on the opposite side window on the OUTSIDE of the body and run a pencil or ball point pen on the detail lines. Remove the tape, cut out the shape with scissors and stick it on the inside and burnish the edge well with the back of your fingernail.
On the subject of masking materials, if you use masking tape, use a high grade 3M product not a .25 cent a roll bargain tape. And some but not all sign vinyls can leave alot of adhesive residue. Good to test it first. Most sign shops throw away alot of vinyl scraps and would save some for you if you ask.
Steve
vegaracer is offline   Reply With Quote
Old 12-14-2008, 12:31 PM   #11
RC4WD TEAM DRIVER
Tomy's Avatar
Thanks for all the tips and tricks!
I finally started painting the body today. It's not finished yet, but so far I'm happy with how it looks. The design is very simple though, nothing like the artwork most people do here.
I tried book covering film as masking tape and it works great! I use it like a liquid mask. First I cover a bigger area, then I mark how I want to cut it, remove it and cut and put it back. Window masks are easy to do and so far no serious bleed throughs.
EDIT: And here it is. It's not perfect, but I'm satisfied with my first paint job ever.
Old 12-15-2008, 07:11 AM   #12
1rcmonster's Avatar
Nice looking very clean first paint job.....
I LIKE IT
1rcmonster is offline   Reply With Quote
Old 12-15-2008, 04:12 PM   #13
not bad like the color combo
hyhflo is offline   Reply With Quote
Old 12-16-2008, 05:01 PM   #14
Looks good for a first time paintjob. Now sticker it up just a little bit. But dont over do it. It will really "pop".
Good job
RC Shocker is offline   Reply With Quote
Old 12-16-2008, 07:00 PM   #15
looks good bro i like it
pedemaster-rc is offline   Reply With Quote
Old 12-16-2008, 07:42 PM   #16
if you are using waterbase paints a good little trick you can do is if you have some small bleed throughs get you a toothpick and lightly wet it and scratch it off.
