Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Paint and Body
Thread: Removing overspray...fawk.
Old 12-19-2008, 12:06 PM   #1
Default Removing overspray...fawk.
I'm painting this tuber I'm working on. I'm using two part paint (base+clear) I got a little overspray on the paint, and out obviously like to remove it before applying the clearcoat.
What can I use that won't damage the paint I want to keep? Is there anything I can do other than kick myself for not masking better?
I also noticed a little overspray on this lexan sheet I painted. The film peeled back a bit on a corner, and wha-la; overspray. I don't want to use brake cleaner becase that will most likely fog the lexan; what can I use?
Thanks for any help!
I can build 'em, but paint is NOT my strong suit...
rerock is offline   Reply With Quote
Old 12-19-2008, 12:23 PM   #2
Powered by Awesome
TwistedXT's Avatar
the clearcoat should actually make it all seem asif there was no overspray.. depends on how bad it is though... on the lexan.. someone makes a paint remever that is safe for lexan.. cant remember who though.. i just know its like 15 bucks a bottle.
TwistedXT is online now   Reply With Quote
Old 12-19-2008, 07:22 PM   #3
I'll look for that paint remover for the lexan.
I broke down and bought another can of paint and repainted teh section that got oversprayed. It was just a dusting, but it was black overspray on red paint. It was 'noticable enough'.
Old 12-20-2008, 08:58 AM   #4
what type of paint did you use. acrylic, enamel, lacquer? First try a tooth pick and see if it will scrape off. the tooth pick won't damage the plastic body. if that doesn't work try household denatured alcohol with a "Q" tip.
caci623 is offline   Reply With Quote
