Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Paint and Body
Thread: help removing window masks thats stuck.
Old 12-20-2008, 08:01 PM   #1
Default help removing window masks thats stuck.
ok, so i have an old hummer body i found in my workshop from about 4 or 5 years ago, i painted it, trimmed it, but never removed the window masked. I tried peelin em off, ha right. they'll don't even scrape off. They've been infused into the body i swear lol. ANy tips on what i could try, using any type of alchohol or anything might get em off, but take body paint with it. .. . thanks
stevomr2turbo is offline   Reply With Quote
Old 12-20-2008, 10:31 PM   #2
yeah dont wait 5 years to do it!
crawldad91 is offline   Reply With Quote
Old 12-21-2008, 02:29 AM   #3
One thing you could try is WD-40. Not sure if it will affect the paint, I don't think so, but you could try. I use it to get old stickers off everything.
Prostreet is offline   Reply With Quote
Old 12-21-2008, 04:28 AM   #4
Back in the WATER!
dpdsurf's Avatar
I would squirt Ronsonal lighter fluid on the tape, let it soak in, and then work it with a terry cloth rag. repeat process as needed.
dpdsurf is offline   Reply With Quote
Old 12-21-2008, 04:02 PM   #5
Default problem
try denatured alochol and a Q tip. Apply with the Q tip and let it soak in for about 30 seconds. you need to get it to soak thru the paper to get to the glue. it will come off. if that doesn't work let me know and i'll give ya a link to a product that will work. however you have to order it online as nobody locally would carry it.
caci
caci623 is offline   Reply With Quote
Old 12-21-2009, 02:20 AM   #6
You could try dish soap and warm water.
wanantrdsc is offline   Reply With Quote
