| | #1 |
| Quarry Creeper Join Date: Aug 2006 Location: Baumholder
| I know it has been asked before but I can't seem to anything about maybe I'am searching wrong. Anyways my question is to achieve the flat paint look should I use a high grit sand paper to take the clear finish off the inside of the body. Or is there a different way? Thanks in advance |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Oct 2008 Location: Glendale,AZ
| Hi, to get a flat finish, you'll need to scuff up the OUTSIDE of the body. Doing it on the inside will still give you the shiney look after painting. There are a few chemical options, that when applied to the outside will turn the plexi cloudy and give a matt finish when the body is painted on the inside. Thus far nobody has successfully been able to do this. I'm experminting and will have some better info in a few weeks caci |
| | #3 | |
| | #4 |
| RCC Addict ![]() Join Date: Nov 2005 Location: Utah
| Mikeymike can do it! His flat paint jobs are sweet |
| | #5 |
| Really? ![]() Join Date: Dec 2007 Location: MT & ND
| CrawlerGraphics (formerly mikeymike1969) has done several flat paint jobs that have turned out very nice and not "cloudy". Contact him and I'm sure he can hook you up Look at this thread for a Grappler he did for another forum member: Mikey mike adn the fresh paint bunch Last edited by montana.matt; 12-23-2008 at 03:37 PM. |
| | #6 |
| ......../-__-\........ ![]() Join Date: Nov 2007 Location: Memphis
| I've seen some that have been painted on the outside. It leaves realistic looking scratches, and as with any other body you can repaint it. I was unaware of a flat paint job method that is still painted from the outside. details please |
| | #7 |
| Rock Stacker Join Date: Jul 2005 Location: vandenberg afb
| flat paint on the out side is the way to go. do silver or a rust color on the inside so when you get scratches it looks like the metal is showing under. i did my chev this way and it turned out sick good luck |
| | #8 |
| Thanks for the information everybody |
| | #9 |
| Quarry Creeper Join Date: Feb 2006 Location: San Jose, Ca
| Im looking to paint the outside of a lexan shell also. if you look a few threads down you will see my unimog 416 body thread. I want to paint a flat sand color on the outside of the shell should I use regular lexan paint? but just on the outside? also gets a little more tricky cause half my body is styrene ... not sure if the paint would come out the same on both plastics... will regular lexan paint work on styrene ok? |
| | #10 |
| Rock Crawler Join Date: Aug 2008 Location: North Augusta
| http://photos.alabamarockcrawlers.co...20(Medium).JPG http://photos.alabamarockcrawlers.co...20(Medium).JPG These are both a body i did with a flat black lexan paint on the exterior of a Betty Body. I want one of CrawlerGraphics bodies! |
| | #11 |
| Gold Star Baby! ![]() Join Date: May 2007 Location: Taylors Falls just hanging with the MNRCRC crew.
| I got this tip from Drumbeater. You can treat the outside with a clear adhesion spray available in cans. It's made by Klean-Strip and it's called "Bulldog" mask your windows then give it a coat let it dry and you can use any good auto paint or primer and it will not chip or flake. It's a little spendy I bought a can from www.spaceagepaint.com for $17 and change + shipping but it is a huge can. |
| | #12 |
| Quarry Creeper Join Date: Oct 2006 Location: Japan
| I have painted on the outside of the shell and finished it with a coat of Flat Clear (TS-80) from Tamiya, it does scratch off however that was my plan and I sprayed the inside of the body a copper colour so it looks like rust ;) |
| | #13 | |
| ... Join Date: Sep 2005 Location: USA
| | #14 |
| Ok I am going to have two bodies painted, as you may already know one will be flat black, have another question well kinda asking everybodies opinion. Now the body will be flat black and hopefully some green and white pin striping, now I am getting eritex comp wheels should I get them black or should I dye the green to bring out the pin striping or will it be to much? Thanks for the help. |
| | #15 |
| Team T1E/VP Driver ![]() Join Date: Feb 2008 Location: High Point
| I always like bringing out color like that... small little color details in the body to accent trim of the wheels or chassis or what ever else is seen! I don't think it will be too much... as long as you keep the pin stirping down a little! |
| | #16 |
| Thanks, I was thinking the same thing. I want something different. I may even have something else up my sleeve. |
| | #17 |
| PapaGriz Yo ![]() Join Date: Apr 2004 Location: Planning
| Painting the outside of the body with Pactra lexan paint gives it a nice flat look. |
| | #18 |
| Oliver Custom Knives ![]() Join Date: Dec 2007 Location: Bloomfield NM , not something stupid
| | #19 |
| Rock Crawler ![]() Join Date: Dec 2008 Location: Humboldt
| Great tips on the flat finishes. I though Tamaya made a flat paint for lexan? If you spray flat on the inside will it be gloss on the outside? thanks |
| | #20 |
| Thread Tools | |
| Display Modes | |
