03-11-2009, 06:48 PM | #1 |
Pebble Pounder Join Date: Feb 2006 Location: Carlisle, Pa
| Painting with a brush?
I just picked up a Blazer CGR body and want to know what paint works best for brush painting the interior? I will be painting from the underside but that shouldn't matter.
03-12-2009, 05:56 PM | #2 |
Rock Crawler Join Date: Jun 2008 Location: Naples
You could use a water based acrylic, like Faskolor with a brush, but it's very tricky to get a uniform finnish. Take a look at this idea: http://www.wisebread.com/make-a-craf...ut-of-old-junk |
03-12-2009, 06:53 PM | #3 |
Rock Crawler Join Date: Dec 2008 Location: Marengo, Ohio
Now thats some ingenuity, only bad thing is the spray isnt very consistant and is blotchy. Id give it an A for execution though |
03-12-2009, 11:09 PM | #4 |
Quarry Creeper Join Date: Oct 2008 Location: Glendale,AZ
Use the acrylics, Faskolors. Use a soft round brush. it'll take 3-4 layers. hold up to the light to see if you have on enough coats. Back it with faskolor chrome not white or black. The silver color is very forgiving and you won't see as many, if any, light or dark areas as you would backing it with the white or black. Ater you've backed it with silver then you can back it with black and then apply your sealer, faskote sealer works great. Check out my work, I paint with a brush all the time! good luck caci |
03-13-2009, 06:46 AM | #5 | |
03-13-2009, 09:23 AM | #6 |
Rock Crawler Join Date: Jan 2007 Location: Tuscaloosa
I have always used the $0.49 stuff found at the hobby store in the craft section. Has always worked good for me.
03-13-2009, 10:09 AM | #7 |
RCC Addict Join Date: Sep 2008 Location: Mccalla,Al
