05-08-2009, 04:56 PM | #1 |
Quarry Creeper Join Date: Nov 2007 Location: Kansass
| Paint mask issues I'm haveing some problems with Spaztix paint masks I bought at my LHS. I didn't have a problem putting them on or getting them to stick. The problem I'm haveing is when I took the masks off, the paint peeled with them. So now I have a big mess of clear space that I'm going to have to clean up and respray black to blend everything back together and make it look decent, I hope. I did the painting about 3 weeks ago so the paint had plenty of time to dry. What I'm wanting to know is if I let it dry TO much before I took the masks off or what happened? I did wash out the inside of the body before I put the masks on or did any painting. I'm really confused. Could someone give me some insite of to what might have happened? This is a first for me. I've not ever had this happen before. |
05-08-2009, 05:00 PM | #2 | |
Quarry Creeper Join Date: Jun 2004 Location: aurora, CO
if it doesnt stick to that, then the paint is the problem and you call spaz stix | |
05-08-2009, 05:06 PM | #3 |
| Thank you for the help. I'm gonna guess it ws the paint that is causing the issue. It's just Pactra spray paint, and it's mostly black, so having an all black truck won't be to bad I guess. |
05-08-2009, 05:22 PM | #4 |
oops sorry i read that wrong, i thought you were spraying spazstix paint, so you wouldnt need the preprep. what was your prep process? just to make sure its the paint |
05-08-2009, 05:32 PM | #5 |
| All I did in the begining was wash the inside with warn soap and water and then rinsed it really well and let it air dry. Then I weeded the masks and put them where I wanted them and used a hair dryer to soften them a bit so they would conform to the curves and then I wiped it down again after I got all the masks on. Then I painted it with Pactra rattle can outlaw black. I havn't done anything to it until tonight, and when I went to peel the masks, the paint came with it. I have yet to take the window masks off, but when I do, I'm going to try to go around them with my hobby knife first lightly so I can cut throught the paint that's there incase it wants to pull off, too. |
05-08-2009, 05:42 PM | #6 |
Built, not bought Join Date: Oct 2004 Location: Gresham
I could be wrong but,I'd say that you left the masks on too long.I've had the same problem before.Hope this helps.
05-08-2009, 05:53 PM | #7 |
Quarry Creeper Join Date: Feb 2009 Location: Rocklin, CA
I find that it's better to peal the mask when the paint is still tacky so it will create a good line. The longer you let the paint cure the more chance you have of pulling some paint with the mask.
05-08-2009, 05:56 PM | #8 |
| Thanks a lot guy's. I really appreciate all the sugjestions everyone has given. I think I DID leave the masks on to long, BUT, I didn't have any problems with the window masks and they were on the same as the others. I thought I was going to have to run my hobby knife around them and didn't even have to do that. Oh well, live and learn, damnit, lol. |
05-08-2009, 06:01 PM | #9 |
05-08-2009, 06:38 PM | #10 |
Quarry Creeper Join Date: May 2008 Location: Oroville
The main reason the paint peels with the mask is paint thickness. If you don't keep your coats thin it'll do it every time. One trick to keeping a clean edge is to pull the mask back onto itself as you remove it. It acts as a knife edge and helps keep it from happening. Hope this all makes sense....good luck with the clean-up |
05-08-2009, 06:52 PM | #11 |
Pebble Pounder Join Date: Feb 2009 Location: Ft. Worth
you can also use an exacto blade to lightly score around the edge of the mask and it will allow the paint to cleanly seperate from the mask
05-08-2009, 08:16 PM | #12 |
| I would like to give thanks to everyone who has contributed to this thread since I put it up. I will deffinatly keep all of your idea in mind for the next paint project. I have since finished everything including the decals, lol. I just scuffed the inside up and got rid of all of the loose edges and then finished it with the original black the rest of the body was painted. I wished I had the abbility to post pics of the finished project so everyone could see what I ended up with but I have no camera. Again, many thanks to everyone who contributed to my delema. |
05-08-2009, 11:06 PM | #13 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
I actually had that same problem monday with Pactra Outlaw Black and Parma Ghostflame masks on a Proline body I painted for my Bandit, only I though I didn't leave the mask on long enough.
