05-31-2009, 05:28 PM | #1 |
Rock Stacker Join Date: Apr 2009 Location: central nc
| which paint for use with canned air propellent?
i have searched but have yet to find an answer. I have a single action testor airbrush i got from walmart years ago in the model car section (our wally world doesnt even sale models anymore). it uses the canned air propellent. the can says consistently over 50psi. what kind of paint can i or should i use? looked at the pactra acrylic but the selection is skimpy. i got an hpi bronco and was gonna use like a metalic green to kinda match my ax10. basically i wanna know what is a good acrylic/waterbased paint for my setup. and while i got ya how bout some color ideas to match the axial green color. thanks sorry i am a noob at paint and basically to rc |
05-31-2009, 06:41 PM | #2 |
Rock Crawler Join Date: Jun 2008 Location: Naples
You could use Faskolor from the LHS, or just plain acrylic craft paint in similar looking little bottles from any craft dept.or craft store. Filter the paint through a fine screen to eliminate any boogers and add only a couple drops of water to each spray bottle which comes with the Testors model # 8821 airbrush kit. Practice on empty 2 liter soda bottles cut in half, to fine tune the spray pattern.
05-31-2009, 07:13 PM | #3 |
Rock Crawler Join Date: Apr 2009 Location: Pa
I like Parma Faskolor. Its water based, dries flexible and sticks extremely well to lexan. With 50psi you should be able to spray it as it comes in the bottle. If its too thick thin it with some water. The Faskolor sticks to lexan better for me than the rattle can paints from other companies.
06-01-2009, 01:40 PM | #4 |
Rock Stacker Join Date: Dec 2007 Location: Stafford, VA
I use a mix of Faskolor and Pactra acrylics. I have had really good results with both of them. As long as the can actually sprays at consistent 50 psi, then you should be fine using Faskolor straight out of the bottle. I use an air compressor, and I shoot at right around 50 psi with no problems from either paint.
06-02-2009, 04:51 PM | #5 |
i want to paint my body pearl green i think and put a black stripe down the side. it would be easier to paint the green and put a mask for the black, instead of outlining the black stripe first. i know darker first but would this work because i dont think i could do the outline way without making it ugly. |
06-02-2009, 08:44 PM | #6 |
you could do that no problem (green then black) but make sure you back the lighter color first with silver or white so that the black doesnt bleed through the lighter color and throw it all off. good luck and post pics when you're done!
06-03-2009, 02:53 PM | #7 |
thanks i was thinkin about maybe having a yellow stripe instead of black cause my grandpa had a truck painted that way.
06-05-2009, 02:05 PM | #8 |
ok i just got my fasgreen and got black and chrome ordered. My question is do i need to use faskoat or is the other faskolors enough?
