08-08-2009, 02:09 PM | #1 |
Newbie Join Date: Aug 2009 Location: San Francisco
| Flat black paint
Hey guys, So I just finished building my AX-10! I want to paint the body flat black, like a rat rod. I don't want any kind of glossy finish. So I bought some flat black paint in a rattle can at OSH that is supposed to work well with plastic. I have cut out the body and I was just going to paint the outside. Is there any reason this is a totally bad idea? On a side note, this is a temporary body while I get my FJ body off of a Nikko 1/10 ready to fit, so I'm not to worried about the paint scratching or chipping. The grittier the better I think.... Any advice would be great as this is my first RC. Thanks! jeff |
08-08-2009, 02:37 PM | #2 |
Rock Crawler Join Date: Jan 2007 Location: Lehigh Valley
Flatting the outside works, just use the correct paint. You can paint the inside a mix between silver and rust so when the outside gets scratched you have some color under.
08-09-2009, 04:41 PM | #3 |
Rock Crawler Join Date: Jan 2006 Location: Southwestern Pa.
08-09-2009, 05:01 PM | #4 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
I painted a B17 body this way. Painted the inside Tamiya Copper, rattle can. Then airbrushed the outside with Fascolor Silver. Then used Krylon Fusion paint over the silver. When the black gets scratched it goes to the silver, to look like bare metal. Once the silver gets scratched the copper looks like rust. Here is a pic of the body.... |
08-09-2009, 05:33 PM | #5 |
Quarry Creeper Join Date: Mar 2009 Location: vacaville
Nice concept |
08-09-2009, 07:52 PM | #6 |
Quarry Creeper Join Date: Mar 2009 Location: Torrance, CA
I used the Krylon Fusion on my Betty body and it starts to flake after a lot of crashes.
08-09-2009, 09:37 PM | #7 |
Rock Crawler Join Date: Jan 2006 Location: Vacaville, CA
try spraying the outside of the body with brake clean. it should dull the gloss... try it on a scrap piece of lexan. I've used it to fog some clear parts of plastic, but you could paint the inside black then the paint wont scratch off and can still look flat.
08-10-2009, 05:22 AM | #8 |
The Fusion paint will not flake if you spray a basecoat of lexan paint first. That is why I use Fascolor silver before the Fusion paint.
08-10-2009, 06:11 AM | #9 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
I use a fine grit sand paper to brush the outside of the body after I paint the inside.
08-10-2009, 11:51 PM | #10 |
Rock Stacker Join Date: Sep 2008 Location: Eastern Oregon
Looks good though. More realistic |
08-11-2009, 12:30 AM | #11 |
RCC Addict Join Date: Nov 2008 Location: Frederick
